Is it working? I couldn't get my AM586 working in my 630.Anyway, I configured it with Q610 PDS + Houdini II + Cyrix 5x86 100GP.
Cyrix 5x86 100GP is an option from reply.
The standard configuration of 6100+Houdini II works,Is it working? I couldn't get my AM586 working in my 630.
Yeah, my Intel DX4 ODP works fine, although the speed increase is small. Shame the boards don't have some cache in them.Does it work with the DX4-100Mhz-ODP configuration?
@jeremywork , these photos have been a great help, but I still can't read some of the chip labels and resistor values. I'm trying to see if I can populate the missing components on a lower tier 200 series card (210 in my case) and turn it into a full blown 290 model. My card is missing both the cache and PCMCIA components. The PCMCIA controller chip at U93 I can read fine in your existing photo, but it also appears that Q3, Q7, and Q8(?) to the left of the NuBus connector (facing down) are also related to PCMCIA and are unpopulated on my card. The components that are missing for the cache appear to be: the cache chips themselves at U2, U3, U4, U5, and U6; some logic gates at U7 and U10 at the top left of the memory slot; as well as U8 and U9 which are located under the voltage regulator heatsink near the OPTi chip.I also took some better quality photos of these Orange386 and OrangePC 290 cards.
I'll try to take some more detailed photos of this card next time I have the machine it lives in on the bench. Can't promise that'll be tremendously soon, but I'll push it up the priority list a bit.@jeremywork , these photos have been a great help, but I still can't read some of the chip labels and resistor values. I'm trying to see if I can populate the missing components on a lower tier 200 series card (210 in my case) and turn it into a full blown 290 model. My card is missing both the cache and PCMCIA components. The PCMCIA controller chip at U93 I can read fine in your existing photo, but it also appears that Q3, Q7, and Q8(?) to the left of the NuBus connector (facing down) are also related to PCMCIA and are unpopulated on my card. The components that are missing for the cache appear to be: the cache chips themselves at U2, U3, U4, U5, and U6; some logic gates at U7 and U10 at the top left of the memory slot; as well as U8 and U9 which are located under the voltage regulator heatsink near the OPTi chip.
There are also some components on the reverse side of the card which seem to differ. The important looking ones are: R20, R21, R22, R108, R109, R110, R111, R112, R113, Q1 and Q2. R20, R21, and R22 are near the back of the card with the rest of the components in question being located to the right of the NuBus connector (facing down).
I believe I've seen that @micheledipaola also has one of the fully populated 290 cards? Any photos where I can clearly read the component text in question would be greatly helpful in this endeavor. Thanks in advance if anyone is able to assist!
I will do my best to take these pics, but as @jeremywork just wrote, I think it will take a bit to find the time.@jeremywork , these photos have been a great help, but I still can't read some of the chip labels and resistor values. I'm trying to see if I can populate the missing components on a lower tier 200 series card (210 in my case) and turn it into a full blown 290 model. My card is missing both the cache and PCMCIA components. The PCMCIA controller chip at U93 I can read fine in your existing photo, but it also appears that Q3, Q7, and Q8(?) to the left of the NuBus connector (facing down) are also related to PCMCIA and are unpopulated on my card. The components that are missing for the cache appear to be: the cache chips themselves at U2, U3, U4, U5, and U6; some logic gates at U7 and U10 at the top left of the memory slot; as well as U8 and U9 which are located under the voltage regulator heatsink near the OPTi chip.
Thanks! This will definitely be helpful when trying to add the PCMCIA to my card. It also looks like most of the logic chips are populated under the PCMCIA card cage on your card? If so, serial/parallel really would just be a matter of adding the GoldStar Prime 2C (or compatible), the 24MHz crystal, and the headers.@evanboonie Here's some photos of my 250 in case they're of help https://68kmla.org/bb/index.php?media/albums/orangepc-250.24/
I am running my tests in a Quadra 650 overclocked to 40MHz. I can confirm that full screen video is kind of bad in most cases. Sometimes, when launching an application, the color gets stuck in grayscale. Switching out of, then back in to fullscreen will make some applications appear in color and run with acceptable performance. Other applications (mostly more advanced games or 3D benchmarks) have slide show level performance on fullscreen, but are acceptable in a window.I've a 290 in a Mac Iici, it runs well however full screen video speed is slow, only OK at quarter resolution on screen for games. Not sure if a limitation of Iici video or the card itself. Be keen to hear if you have similar peformance on your card.
