In my SE/30—which has had its power supply capacitors replaced, thicker wiring installed, and four expansion cards added—the voltage at the floppy drive connector is approximately 4.75–4.78 V. The computer runs perfectly, even when launching demanding games (such as Warcraft).
However, once the Diimo 030 card is inserted (into the PDS slot), the voltage drops to 4.72–4.74 V—even when no other cards are installed. The computer fails to boot: there is no startup chime, and black bars appear on the screen.
Is this kind of voltage drop normal when installing this card?
Should I increase the power supply's output voltage, or should I look for a fault within the Diimo card itself?
