Last update was last November... @warmech ? Any news?Is there any update on the Tash unit for the HD20? I'de love to have FOUR of those!
Man, I hope this comes out. I don’t use the TashTwenty because it doesn’t allow a pass through for a floppyemu.Last update was last November... @warmech ? Any news?
2023-11-04 12:43:41 -0400 - Programming...
Device Erased...
Programming...
The following memory area(s) will be programmed:
program memory: start address = 0x0, end address = 0xddf
configuration memory
program memory
Address: 1 Expected Value: 28a5 Received Value: 0
Failed to program device
My first instinct is to suggest this might be a power issue. Are you powering the chip from the programmer? If so, I'd suggest powering it externally - I've had issues with Microchip's programmers and powering circuits from them, even if the circuit is literally just the chip by itself.Address: 1 Expected Value: 28a5 Received Value: 0
After trying again on a PC with the same results, I changed from clips to better connections and it flashed ok. disregard, looks like it wasn't a good enough connection to enter programming modeI'm having problems programming my PIC16F1704, Pickit3 is detecting, reading and erasing the chip but when trying to program the 20220621-1704.HEX I'm getting the following in MPLAB IPE v6.15
Is there something stupid I just don't know to set yet?
Code:2023-11-04 12:43:41 -0400 - Programming... Device Erased... Programming... The following memory area(s) will be programmed: program memory: start address = 0x0, end address = 0xddf configuration memory program memory Address: 1 Expected Value: 28a5 Received Value: 0 Failed to program device
Working on it but need some info from the creator to complete. I just built one tonight to try out.Just discovered this thread and was curious if the 'TashTwenty' with stepper motor actuation ever came to fruition? I've had an HD20 with bad drive here for 20+ years that would be ideal for this device. I'm no stranger to a soldering iron and SMD, but am not currently set up to program a PIC. I see a TT-Tiny for sale, but would love to get that audible stepper action.
Any updates?
If you have a PICkit2 or 3, give PICkitminus a try for programming: http://kair.us/projects/pickitminus/
