SE/30 - Making progress!
After cleaning, removing the (thankfully unexploded) battery, logic board recap (tantalum polymer), reflowing the solder on the analog board, keyboard and mouse clean, retrobrite...
Today, I booted with the Rominator II and 128mb of RAM.
So far so good but I have a few things left to figure out.
1. I have an occassional seemingly random screen jitter. I do have that burned pin on the CRT connector which I believe is caused by faulty analog board caps...I hope, because I plan to recap that board and the power supply as well. I'm also replacing the connector (parts in the mail). I understand this could be caused by a failing flyback transformer. I looked and listened in the dark and it is not making any sound or arcing when powered on.
2. When I got it, it booted to the question mark. I assumed the inabilty to boot issue was a failed Quantum 40S. After taking that hard drive apart, I confirmed the black goo issue that tends to make these drives fail. So I have no reason to believe there is any problem with the SCSI bus on the board and some evidence to the contrary. Currently I have nothing connected to the SCSI connector on the logic board. When I launched SCSI Probe, It said "Bus Not Terminated" which I assume is a good thing because that sounds like it recognizes the bus but obviously sees it as not terminated since there is nothing connected. Again, I have no reason to doubt the board but that sounds like its doing what it should do with nothing connected, right?
3. Why when booting from the ROM disk, the System Software appears to be using most of the installed RAM? (see pic) Is this normal?
Thanks as always for any assistance/knowledge!
32-bit addressing isn't turned on.
ah ok...I thought that was the point
of the rominator being clean?
There are no control panels on the ROM disk (except SCSI Probe). Does it only function as clean when booting from a drive or floppy?
You still need to turn 32bit on. If you go to the memory control panel (Apple Menu>Control Panels>Memory), then turn on 32 bit Adressing and restart.
ok the Rom Disk is extremely minimal. No memory control panel. The only control panel is SCSI probe. But good to know when I put a real drive and OS on it. Thanks.
32-bit clean means you can turn on 32 bit addressing, not that it must be turned on. Older software sometimes objects to 32-bit addressing mode. The setting is stored in PRAM. You can turn it on in the Memory control panel.
You should have it terminated really. If you connect something externally you should have something connected and terminating the internal end of the bus.
Oh yes, I definitely plan to install some kind SCSI to SD with termination. I just meant - is that what I should be seeing under the current circumstances with nothing connected.
fixed the jittery screen by putting new solder on the points on the analog board and tightening the ground wire to the chassis. I am declaring this one a victory and moving on. Thanks 68kmla!
