Hello,
I thought I knew how to do this but it’s not working for me.
System: G4 Gigabit/ 500Gb SATA SSD (IDE-SATA Adapted. Pins set to “Slave”) 6 Gb IDE (“Master”) /500 MB RAM.
SSD Partition scheme:
77 Gb (OS 10.4)
30 Gb (Set aside for OS9)
10 Gb (10.4 Boot load)
10 Gb (Set aside for OS9 boot load)
6GB IDE HDD (OS 10.4)
Here’s the steps I tried:
Downloaded 9.0 and 9.2.2 universal from MacintoshGarden
unzipped and mounted .iso with Toast 9.
CDRW Image appeared on desktop.
Tried methods:
method 1:
dragged system folder to OS9 boot disk.
Tried to make it “blessed” by dragging system suitcase out of and back into system folder. NOTE: system suitcase folder isn’t a suitcase shape.
Launch preferences > startup disk: Drive shows up with OS9 logo over Drive logoChoose this. Restart.
boot chime, OS 9 starts loading then I get THIS ERROR
method 2:
From within 77 Gb Booted partition: Double click OS9 CDRW image. Double click install. OS9 and installation software show up and start bouncing in dock below. OS 9 window appears and OS9 starts loading then I get the same error as before.
NOTE: I tried this method from inside the 6GB HDD by copying the 9 CDRW disk image into the desktop image as well while booted into SSD. No change.
Method 3: Burned OS9 CDRW image at 1x speed. Load and Boot into this disk.
Same error.
Method 4: Booted into OS 10.4 boot disk. Launch disk utility. Attempt Restore OS9 disk to OS9 Boot Disk Partition using drag and drop. NOTE: System Suitcase is Greyed out. Process finishes. Preferences > startup disk > choose OS 9 Boot Disk.
SAME ERROR!
tried all 4 methods with 9.2.2 universal as well.
I’m out of ideas. Wth am I doing wrong and what does this error verbiage mean? Is it some sort of copyright protection scheme to prevent us from using anything but a retail disk?
77 Gb (OS 10.4)
Tried methods:
method 1:
method 2:
Same error.
SAME ERROR!
