Options for Lisa 2/10 hard drive replacement?
Hi all,
I have a Lisa 2/10 that has a very loud and often stuck hard drive. I know it's a matter of time before it dies. I'd like to replace it with a modern drive of some sort. Since I'm more of a Mac guy, I don't know much about the type of drive it is or what are the potential replacements. it says "Widget Controller Two Layer" on the top of the stacked boards. I guess widget just means hard drive?
Any advice or links to products would be appreciated.
I'll have to get the OS off of it or maybe just download a new one. I have a Floppy emu if that helps. But I want an internal solution ultimately.
There have been a number of replacement projects over the years, including those based on chips that have gotten hard to source due to shortages. I think the newest one, with a deep connection to the the most advanced work in Lisa recreation, is the ESProffile:
On My Lisa I see 2 ribbon cables, a fat one and a skinnier one along with 2 power connectors. Do all of those attach to the ESProFile? Is there a setup manual anywhere?
The frontmost ribbon cable is the drive interface. This is the ribbon cable you plug into the ESProFile.
The small electrical connector goes to the fan in the floppy/hard drive mounting cage. With the Widget removed, there's nothing that needs that kind of cooling, so you can leave it unplugged.
The large electrical connector is the power connector. There are two ESProFile form factors: the "internal" and "external" kind. If you get the external kind, you will need to adapt that power connector to a MicroUSB connector somehow: it's not that hard to do depending on how professional you want to be about the job. If you get the internal kind, you will be able to plug this connector into a built-in receptacle on the board.
The rearmost ribbon cable is part of the Widget and connects to another of the Widget's circuit boards.
Is Patrick Schaefer's idefile project defunct?
I don't have any reason to believe so... drop him a line and see if he will supply you with the GALs and a PCB. It's a good kit that makes a fast and dependable emulator. But it's definitely a project that you must find parts for and assemble; you must use compact flash cards (or an old parallel IDE hard drive) for storage; and it's considerably more difficult to move disk images between the storage device and a modern PC. (For Linux or Mac users, familiarity and comfort with the dd command is a real asset. For Windows I would not know where to begin.)
Sorry for the misunderstanding, but I built an idefile many years ago and am delighted with it. Was just curious why I don't hear anything about it these days.
If you need an ESProfile PCB let me know, I'm in the process of replacing the drive in my 2/10 and I had to order 5 of them to get the run manufactured.
The ESProfile will work with an Apple III, correct?
I thought it did, but it looks like that was only somewhat temporary and that it doesn't support the III right now. It might help to drop @AlexTheCat123 a line though to see whether this has changed again.
As for dealing with getting images onto an IDEFile, it occurs to me that you could probably get an AI to do a lot of the heavy lifting these days, if you were inclined that way.
