Finally got my MP 2000 online using a Lucent WaveLAN silver card. 3 hours it took me to work out the settings! Kudos to the Japanese guy for writing the drivers.
I've a Lucent Wavelan Gold but the driver installed doesn't work. I assume I need to find the Newton Internet kit, but am having difficulty working out where it can be found?
I wish that the driver was totally free and WEP worked no matter. Also, that little slip that comes up every time I soft reset telling me to register gets annoying.
WPA would be nice, but I don't see it happening. They got it on the airport card, which is a special lucent wavelan.
i'm having troubles getting it to work on my emate. how do i configure the driver? what files do I need to install from the NIE? and why dont the lights come on on my wavelan.
downloaded and installed the wavelan drivers and it eventually worked with a lot of playing around. It's dammed temperamental and a pain in the arse to set up but it does work.
go into Owner info and set up a new worksite and add all your details, wifi setup etc in there. Then when you use Newtscape (or whatever) to surf, connect using that worksites info.
Not sure if anyone is still monitoring this thread, but wondering if anyone can explain the -60088 error I'm getting with a Lucent Wavelan IEEE Silver and both my MP2100 and eMate. I have Eero mesh wifi at home and have also tried the hotspot on my iPhone. It seems to hang on 'getting DHCP configuration' before the error message pops up.
