More pico-mac stuff
Really interesting how the cost function changes when your host clock is 20x faster than the emulated cpu.
Also when the number of regs differs. You mentioned earlier that you use global registers, but I’m not sure I understood - does that mean that A0-7 and D0-7 each get stored in a (cortex) memory location? Or do you map certain 68k regs to cortex regs?
Just going back to the instruction backlog issue with MIDI: this was a problem with real hardware as well, which is why MIDI includes spec for external clock and clock sync. Sometimes of course, those aren't an option, which is where cycle exact emulation shines.
I really like the idea of an emulator where one thread is used to manage each hardware implementation, and another thread is used as the IO monitor, such that synchronization is managed by a central loop that doesn't reflect a part of the original hardware. This also makes it much easier to toss in another piece of hardware or tweak a component after the fact, without having to deal with timing issues. But for this to work, you need to ensure that your loop is cycling faster than the fastest expected combination of IO signals, so you're always assured you're back at the next cycle for any piece of hardware before you get a collision.
Yes and that's today's topic (I think, assuming I know what you mean by cost function)!
Today I did something ILLEGAL!
Yes, I implemented the ILLEGAL instruction!!! In many ways, ILLEGAL is pretty simple, because it doesn't need to do much computation, it just causes an exception. But that meant I needed to implement the beginning of exception handling and in so doing I learned something about the Davidian PowerMac 68K emulator. I know that Exception emulation is going to be much faster than the way a real 68K would generate an exception stack frame, because the Emulator can store a word on a stack in the equivalent of 0.1 68K cycles.
So, that means I can use a single routine to generate both kinds of exception stack frames:
Format A
Offset from SPSizeValue
+0WordFlags:
Bit1514131211109876543210
Def0:Write 1:Read0:InstructionFunction code
+2LongwordAccess address
+6WordIR
+8WordSR
+10LongwordPC
Format B
+0WordSR
+2LongwordPC
An ILLEGAL instruction is Format B. On a 68000 it takes 34 cycles, equivalent to 654 cycles on an RP2040 at 125MHz. So, my Exception routine currently takes 100 cycles for ILLEGAL, which is 6.54x faster than a Real Mac.
What does this mean? It means that whereas there's quite a significant overhead for taking exceptions on a real Mac (added to the cost of the trap dispatch), on the emulator there's a relatively low cost, which also applies to 'A'line and 'F' line traps. And this means that ToolBox calls, particularly fairly trivial ones like Rect calculations, are relatively much faster.
So, this also provides an insight into the Davidian PowerMac 68K emulator, because Gary Davidian's emulator would have found exactly the same thing: generating an exception frame in PowerPC code would have been relatively fast compared with normal instruction emulation. However, on top of that, the Davidian emulator emulates the Mac ROM's 'A' line trap dispatch entirely in PowerPC code too. So, instead of perhaps a dozen or more (other people here know) 68K instructions dispatching to the correct ToolBox function which would individually get emulated; an 'A' line instruction performs both the hardware operation of the trap and the dispatch entirely in native PPC.
So, it'll be relatively faster.
Partly. The first issue, which is also true for any 32-bit ARM emulation of a 68000, is that ARM doesn't have enough built-in registers to emulate D0-7 and A0-7. So the emulator defines a Context data structure containing all the regs and when the emulator needs to access one of them it must perform a LDR rd,rContext,#RegOffset to load the reg; then some ALU stuff; then a STR rd,rContext,#RegOffset to store it at the end.
And this is what the Cyclone 68K emulator does explicitly, because Cyclone is written in 32-bit ARM code. However, a number of critical 68K registers can be globally allocated to ARM registers. For example, MØBius allocates the Instruction Register; the CCR (not SR); the PC; the pointer to the CpuContext to the 68K regs all in Cortex M0 registers. These are the ones most frequently used, i.e. on pretty much every instruction. PC isn't even the real 68K PC - it's pre-mapped to Cortex memory, either somewhere in Flash when executing ROM code or Cortex RAM when executing RAM code. That way I can pick up the next instruction just with an LDRH rather than having to translate the logical value of PC to a physical Cortex location.
But a 'C' emulator has additional problems, because the developer might not be able to get the compiler to allocate global registers and even if it did, it'll be more restricted, because compilers will need more temporary host registers to compile efficiently. So, probably on Muhashi(?), there are no Cortex registers globally allocated to 68K registers and again, that'll slow it down with lots of LDR, STR instructions from the Cpu Context.
Sure, but unless Cycle-exact emulation is different to Cycle-accurate emulation, then it still won't fix that issue. Cycle-accurate emulation counts the right number of emulated CPU cycles so that the emulated CPU executes the same number of cycles as the real CPU would per time slice.
But it still executes the corresponding instructions as a block before performing its other emulation tasks (i.e. the IO stuff and video etc). Then at the beginning of the next time slice it synchronises real-time with the number of cycles emulated in the previous time slice.
So, if the emulated CPU picks up MIDI clock events, then it partly solves it. The CPU knows when to send the MIDI events on playback, but its sense of time is still compressed, so either the events still get sent in a fraction of the time (even though the CPU thinks it's sending them at the right time), or they're sent to a buffer which then handles the I/O after the emulated CPU time slice and then the events still come out as a block. This is what I saw with miniVMac and PCE-Mac with cycle-accurate emulation.
Conversely, MØBius isn't cycle-accurate at all, but it will be able to correctly run MIDI software in accurate real-time, because it has a core dedicated to running the CPU emulation.
But maybe cycle-exact as you say is also a core dedicated to CPU emulation and does:
C:
void CpuTask(void)
    ns=CpuExe(1); // Execute one instruction and return cycle time in ns.
    while(nanos()<ns)
        ; // Stall until real-time reached.
    // Don't perform any IO or video - that's on a different Core.
Yes, then it would work.
Indeed. That sounds very clever - and challenging unless you have a really fast, modern CPU. It might sound like I'm trivialising it by only remarking on it briefly, but in reality I'm too mind-blown by the concept to comment on it until I learn more about it. It sound incredible though and thanks for introducing me to it.
MØBius is going to be fairly fortunate, because original Mac hardware is so crude, the second core won't need to do much synchronisation ... he says naively! For example, I think I can emulate the VIA using the RP2040's own timers. It should be possible to map serial functions directly. Video will be a background task using DMA and the second core for some of the critical stuff to restart video frames (this is pretty standard). Audio. A really accurate emulation would need 15kHz interrupts on the second core so that Mac software that races the beam to fill in audio samples would still work, but I think I'll just copy the buffer on every frame and then play that out using DMA. Mouse and Keyboard is USB to original Mac protocol, but it doesn't need to be µs accurate timing (and it can't be, because you won't get a USB mouse XY change faster than every ms). I can probably use pico-Mac's code. Disk emulation won't emulate IWM, but use the fake Sony driver concept to access a Flash file system. However, I should be able to support about 1.2MB to 1.6MB even on a basic PICO's internal Flash (one 800kB disk and one 400kB disk). SD support will be an upgrade, but perhaps I can port that code from the existing pico-mac.
IIRC (fuzzy memory, it was a long time ago), I think this is what Paul eventually ended up doing for Mac II audio in Mini vMac. It works well enough for everything I've thrown at it! He spent years trying to figure out how to get the Mac II audio to sync properly, and eventually just settled on frame-by-frame, ignoring the random stutter this can theoretically produce. I do also remember him having a mild issue with the buffer he was filling, but I don't think that was an implementation issue, just a "oops, forgot about that blocking event!" issue.
It's tricky. Theoretically, one of the nice things about having direct access to hardware in a bare-metal implementation is that accurate audio could be done without tying up a core at all. Here, you get a 15kHz timer to trigger a DMA channel which copies the next pair of bytes to the audio. Then a PIO plays every other byte (because one of the bytes is used as a PWM controlling the IWM's disk rotation speed). But for most purposes, just copying the entire buffer in one go and playing that at the right rate will be fine for most purposes and simpler.
Today my big achievement was *NOTHING*! Yes, I finally implemented NOP! In the meantime I've implemented TAS, TST and TRAP.
MØBius has a 256 entry vector table for the upper byte of an opcode, but many 68000 instructions have multiple instructions encoded within the low byte of a single vector. I could create more dispatch tables, but each 256-entry table would require another 1kB for the emulator, but such tables would be very sparse.
So, in these cases, I perform a binary subdivision to decode the rest of the instructions. In the worse case, that would also seem to require at least 128 bit tests and 128 branches but that's half the space and as I just wrote in fact the low byte decodes don't contain many instructions, in practice it wouldn't take many tests and branches.
An ARM Cortex M0+ doesn't have bit-immediate test instructions (unlike a 68000's BTST instruction), so the easiest way to perform a bit test is to shift it, e.g. to the most significant bit and then do a branch on whether the result is -ve:
C:
    lsl rd,rOpcode,#(31-9); puts bit 9 into bit 31.
    bmi OpBit9Set
OpBit9Reset:
    ;An instruction to emulate or more decoding.
    b rNext
OpBit9Set:
    b rNext
In fact though we can do better than a simplistic binary search, by making use of both the carry and negative flags to decode 2 bits with one shift:
Code:
    lsl rd,rOpcode,#(31-8); Bits<9:8> to go Carry:N.
    bcs Op1xPattern        ;1x pattern
    bmi Op01Pattern ;01 pattern
Op00Pattern: ;3 cycle decode.
    b rNext
Op01Pattern: ;4 cycle decode.
    b rNext
Op1xPattern:
    bmi Op11Pattern
Op10Pattern: ;4 cycle decode.
    b rNext
Op11Pattern: ;5 cycle decode.
    b rNext
Thus we can decode 2 bits at a time, taking from 3p to 5p cycles (where p is the number of bit pairs). This will be quicker than vectoring for up to 4 or 5 bits and hardly slower for up to 8 bits.
For the $4Exx block that includes NOP: {TRAP, LINK, UNLK, MOVE USP, RESET, NOP, STOP, RTE, RTS, TRAPV, RTR, JSR, JMP} there are a lot instructions to decode that way, but it's still going to be easily efficient enough to this kind of decoding.
On a full, original, 32-bit ARM instruction set you can use the same technique to perform, e.g. bit counts faster than trying to generate AND masks and then branching based on them.
Again, this kind of testing would be less efficient in 'C', because you can't do a 4 way branch (though you could do a simple binary subdivision).
I hope people aren't finding it irritating that I'm providing a near daily update for MØBius.
Today was a bit of a show-STOPper!! Yes, I implemented STOP along with {LINK, UNLK, MOVE USP, RESET, STOP, RTE, RTS, TRAPV, RTR}.
That's a lot of ops in one day, but most of them are closely related, because they either involve pushing or popping from SP; accessing SP or USP; trapping on various conditions (e.g. privilege mode) or switching from Supervisor to User mode. This means that for this block of opcodes, only JMP and JSR remain (and they're basically PEA/LEA type instructions).
STOP correctly implements the trace flag, but I think I need to update RTE to support Trace. MØBius doesn't and won't need to check for interrupts, exceptions or trace on every instruction fetch; which helps to speed things up. This is because:
  • Real Cortex M0+ interrupts will generate interrupts on MØBius - by changing the Next Reg's value (MØBius instructions execute the next instruction by executing b regNext . So, by changing the value of the register we can make the CPU take an exception or interrupt at the right point - i.e. after the end of the currently emulated instruction). This is similar to how a number of Forths implement execution tracing without any performance overhead.
  • In other cases, exceptions, trace and switching between Supervisor and User mode only matters when there's a state change to SR.
Here's an interesting question: we know the early Systems and 68K Mac ROMs use the upper 8-bits of 24-bit addresses for various memory management flags. Do they also use CCR<7:5>, which as I understand have no official use on an M68000? I would have hoped not, because it's so easy to trash those bits using a MOVE <ea>,CCR instruction.. and on early 68K ROMs, the Mac runs in Supervisor mode anyway <facepalm> so even MOVE <ea>,SR is allowed!
It would still be OK if 68K Macs did.
Personally, I'm enjoying the daily updates :) Keep them coming!
I don't know if CCR<7:5> is used at all, but I don't see any reason why they would do so? As you say, early Macs were running in Supervisor mode, and the OS and Frankensteinian ROM then had to account for that in later revisions. And by the time they would have been thinking to refactor or rewrite that logic, PPC and Copland were already on the horizon.
I think you can set up a DMA to fill the PIO fifo at full speed, and then set the PIO to run at 15kHz. The DMA can be paced by whether the fifo has space, so you could initiate it and it would keep feeding the PIO as needed. Which is pretty much exactly what you said, except that “copying the entire buffer” can be a DMA.
How large is the audio buffer? Do programs fill that buffer and then enable audio, or do they trickle the data in? I think you would need to know the number of words to transfer via DMA, but I guess you could periodically check if there was more data in the buffer and restart the DMA
I think that's what I intend to do initially.
The PIO buffer FIFO would essentially achieve the same thing as a proper 15kHz trigger for the DMA, so that's a good point.
<snip> How large is the audio buffer? Do programs fill that buffer and then enable audio
On an early Mac, there's a (I think) 370 x 16-bit word buffer and the individual bytes from each new word is output to a pair of PWMs, one for the IWM drive speed and the other for audio (the PWM + filter is a cheap DAC). So, audio is synchronised to scans (as it would be for UHF video for a TV) and the audio is basically enabled all the time (filling it with 0x80 = silence).
(search for: "THE SOUND GENERATOR".. "The sound circuitry scans the sound buffer at a fixed rate of 370 words per
video frame, repeating the full cycle 60.15 times per second")
I was / am working on a Mac Plus-era application I call Page-Aaah (a pun on the Fairlight CMI's Page-R) which would generate 4-channel sampled audio on the fly by writing to the buffer directly, so I'd certainly hit that problem. Racing-the-beam with the audio gives a bit extra time to generate audio, so it can make sense.
Let's consider what happens if Audio generation takes 75% of CPU. If you start generating samples at the beginning of a video frame (kicked off by the VBL interrupt) then you'll gradually over-take the scan line generation. That's good, because it's a disaster if you fall behind. By the end of the buffer, the scans will only be 75% of the way through. This gives you 25% of a frame left for other tasks (equiv 1.65MHz 68000, not much).
But that's quite tight, and if your VBL is delayed a bit you'll get glitches at the beginning. So, instead it's probably better to start audio generation half-way through the buffer at the beginning of a VBL. Then, the hardware could delay you by up to half a frame; it wouldn't glitch and you'd still be ahead of the beam. By the time you wrap round to the beginning (for the 'next' frame of audio), the scan is 37.5% through the buffer; by the time it's 50% through the buffer you're only 25% through the new buffer. Finally, by the time you've finished the next half of the buffer, the scan is 75% through buffer.
So, then it still takes the same amount of time, but you've allowed for more latency (e.g. mouse interrupts or other timer/housekeeping stuff in a VBL).
Oh, I should add another note to that: in the Linux document (and in the early Mac hardware documents), it explains that there are two sound buffers just like there's two video frame buffers and you can use VIA port outputs to switch between them. Later Macs added much better audio buffering that wasn't synchronised to what would be the Mac's 512x342 screen (which doesn't exist once Macs had higher resolution/colour video) and I think at least one Compact Mac design didn't have the second video buffer either. So, in my description above, I'm just assuming using the single, main audio buffer. There's a discussion about this on the 68KMLA, I think perhaps w.r.t the KABOOM game - it's all about avoiding audio pops on an early Mac.
(Did @jkheiser finish KABOOM?).
We need a countdown! What is it, about 25 instructions left?
Good point too! There's 36 opcodes left and between 25 and 32 instructions left after today's update! So, very good guess!
Thanks, that's encouraging!
That's what I think. On further reflection, I don't think it'll cost anything (or much) in the CPU to maintain those bits :) !
Today's update includes JSR, JMP (very similar), which fully completes the $4exx instruction block. It's amazing how short an emulation for some instructions can be: both of them put together (they share code) take just 7 x 16-bit words, i.e. 14 bytes. This includes 3 subroutine calls, but because even a JMP takes 8 Cycles there's plenty of time.
I've also completed MOVEM.W/L <ea>,regList It's much shorter than MOVEM.W/L regList,<ea> (36 bytes). I can see I made a mistake in that my current code only handles Words and gets the source/destination wrong - other than that - it's great :ROFLMAO: ! So, I'll need to fix it.
Finally I've implemented LEA, which is very much like JMP and PEA except the <ea> value goes to an address reg. Again this is short, just 18 bytes long. If the other instructions were this compact (they won't be), the rest of the emulator would only add 450 bytes!
This brings me to my next topic:
XIP Cache Performance
Originally I aimed to get MØBius into 16kB of Flash so that it would fit in the RP2040's XIP cache. Increasingly it looks like the emulator will fit in 8kB, just half the RP2040's cache! To me, that's fairly mind-blowing, given that we're used to a 68K emulator being fairly hefty with the vector table itself taking up 256kB!
You might think there's nothing to be gained once the emulator is <16kB, but that's not true, because the XIP Cache will have to share both emulator code, Mac ROM code and disk blocks (unless a Disk block is DMA'd directly from flash to RAM using the replacement Sony driver, but that sounds complex to me). How well will it handle sharing both?
The RP2040, 16K XIP Cache is two way set-associative with 8 bytes per cache line. So, every cache access is checked rather like a page table: the address bits for the cache line pass straight through; some or all of the remaining address bits up to the size of the cache index a line in the cache; a number of address bits are then used as a tag to check whether an access is a hit or miss and some of the remaining bits are a hard-coded tag (i.e. because only part of an address range is cached, the rest is non-cacheable).
If the RP2040 XIP cache was one-way set associative, the layout would be:
RangeTagSetIndexLine
0x10000000 .. 0x10FFFFFF A23:A22:A21:A20:A19:A18:A17:A16:A15:A14A13:A12:A11:A10:A9:A8:A7:A6:A5:A4:A3A2:A1:A0
The 11 address bits A<13:3> would index a cache line and if that cache line's tag matched the address bits A<23:14>, there would be a hit, otherwise there's a miss and the cache controller would load 8 bytes from flash and update that cache line's tag.
But the RP2040 XIP cache is two-way set associative, which means that there's only 10 cache line index bits, but the tag for each is 11 bits.
0x10000000 .. 0x10FFFFFFA23:A22:A21:A20:A19:A18:A17:A16:A15:A14:A130A12:A11:A10:A9:A8:A7:A6:A5:A4:A3A2:A1:A0
0x10000000 .. 0x10FFFFFF A23:A22:A21:A20:A19:A18:A17:A16:A15:A14:A131A12:A11:A10:A9:A8:A7:A6:A5:A4:A3A2:A1:A0
I am going somewhere with this! For every cache access there's now two options for the address being cached and if there's a cache miss, then (probably) the cache line for the least-recently-used set gets replaced with the new data.
Now let's think about what happens when the emulator is basically 8kB. The emulator code, relative to whatever address, but 0x10000000 will do, will occupy 0x10000000 to 0x10001FFF of the cache ie. a range where A<12:0> goes from 0000000000000 to 1111111111111, which means it'll occupy the whole of one set. And, unlike an emulator with a vector for all 64k opcodes; the 256 vectors in MØBius will ensure that that set has a high utilisation: a much higher utilisation than any Mac ROM or Flash disk fetches (because those addresses will only be accessed every 10% or less of emulator address access).
So, in turn it means that the Mac ROM and/ or Flash disk will be (for the most part), cached in set 1 of the XIP 16kB cache and will function like an 8kB direct-mapped cache. And this means I can calculate the likely hit/miss rate for the Mac ROM!
To do that I'll reference the Bible for Computer Archictecture: "Computer Architecture, A Quantitive Approach" by John L Hennessy and David A Patterson. Chapter 5 is on memory hierarchy where we find, in section 5.2, Figure 5.7:
SizeInstruction CacheData CacheUnified Cache
8KB1.10%10.19%4.57%
Because the XIP cache isn't a harvard cache, it's intuitive to think it'll function as either a data cache (because the Mac ROM is accessed using Cortex M0+ ldr instructions) or a unified cache with a miss rate of 4.57%. But it won't, because the Mac ROM is a ROM of instructions: it'll function as an 8kB, direct-mapped Instruction cache, just like a cached ROM would if the emulator was in fact a microcoded CPU, like a real 68000.
Now we can calculate access times for the ROM, because if it's terrible, it'll make a significant impact on the emulator's performance. On the XIP cache, hits take 1 cycle and misses take an awful 40 cycles. Yike! But the miss rate is only 1.1%. This gives a combined cycle time of 1c x 98.9/100 + 40c x 1.1/100 = 1.429 Cortex M0+ cycles on average.
An encouraging result, Mac ROM access can easily be tolerated. If 10% of emulator accesses are to the ROM (worst-case, i.e. when running a Toolbox trap), then It'll cost another cycle 42.9% of the time, an overall performance hit of 4.29%, leading to 95.9% of the ideal performance. :cool: !
Today's update and a curious CCR inconsistency!
A few new instructions: CHK, ADDQ, SUBQ, Scc, DBcc!
Most interpretive emulators have extensive flag-handling code that handles individual flags across a number of statements. For example PCE-mac's M68K emulator does:
C:
void e68_cc_set_add (e68000_t *c, unsigned d, unsigned s1, unsigned s2)
    uint16_t set = 0;
    d &= 1;
    s1 &= 1;
    s2 &= 1;
    if (d) {
        set |= E68_SR_N;
        if (s1 && s2)
            set |= E68_SR_C | E68_SR_X;
        if (!(s1 || s2))
            set |= E68_SR_V;
    else {
        if (s1 || s2)
        if (s1 && s2)
            set |= E68_SR_V;
    c->sr &= ~(E68_SR_X | E68_SR_N | E68_SR_V | E68_SR_C);
    c->sr |= set;
Code like this makes sense for a portable implementation, because you can't rely on the underlying architectural features. It's not fast though. I want to avoid this, by using the Cortex M0+'s flag handling as much as possible. This also makes sense in MØBius, because the Cortex M0+ has a very similar set of flags: NZCV to the M68000's XNZVC. But note: C and V are the opposite way around.
Most of the time this doesn't matter, because most real code just performs an arithmetic, bitwise or compare operation and then takes a jump based on a meaningful conditions such as EQ, NE, GT, LT, MI, PL, CS, CC etc where it wouldn't make any difference what order they're in. As long as the flags have the same meaning, then simply recording the Cortex M0's flag results after the operation itself is good enough.
And most of the flag results on a Cortex M0+ match an M68000. This means we can also optimise conditional evaluation for instructions such as Scc, DBcc, Bcc. Instead of analysing the individual bits for the relevant condition code, we can just vector on the M68000's condition field to 16 conditions that all look like:
Code:
;... earlier conditions 0000 to 1001
bpl CpuCcrTestTrue ; 1010=Pl
b CpuCcrTestFalse
bmi CpuCcrTestTrue ; 1011=Mi
b CpuCcrTestFalse
bge CpuCcrTestTrue ; 1100=Ge
;...later conditions 1101 to 1111
And that's very fast. But I found out it's not quite right! On an ARM CPU, the carry output is the same in many cases, except for subtracts and compares, where's it's inverted. This has two consequences:
  • Firstly, BHI and BLO are evaluated differently. On the 68K it's ~C & ~Z, but on ARM it's C & ~Z. Likewise, LO is C|Z on the 68K, but ~C|Z on an ARM. This is a consequence of the 6502 8-bit CPU performing a subtract a,b as cy:a+~b+1 rather than a-b.
  • A subtract instruction must invert the carry. However, this won't fix the problem above, because BHI and BLO will no longer perform the correct Hi and Lo test (they would if we didn't invert carry for subtracts, but then all the other cases where someone might use HI or LO conditions on a 68K would be wrong).
I fixed the former by forcing a short-circuit evaluation. for Hi, seeing Carry=1, means it's false, else it's an NE test. For Lo, seeing Carry=1 means it's true, else it's an EQ test. So, this costs a couple of cycles for those tests.
I fixed the latter by inverting bit 1 of the emulator's CCR reg (which is carry, because it's in ARM format). Interestingly, most of the other flags work the same way (e.g. N and V) thus signed compares still work as normal even for subtracts.
31 opcodes, 20 to 26 instructions to go.
Conclusion: copying existing functionality from another CPU really can help with emulation performance, but subtle differences can be tricky!
Today's update. New instructions: { BRA, BSR, Bcc, MOVEQ, DIVU, DIVS}.
There's not much to be said for all of these. The RP2040 has its own ROM-based divide routines which are fast, but because I think, maybe MØBius could get ported to other Cortex M0+ microcontrollers; I wrote a straight-forward DIVU routine and then just wrote DIVS by the straightforward method of XOR'ing the signs of the operands; and ABSing them.
One (IMHO) interesting artefact I deduced was that I didn't need an extra register for storing the sign of the result. The loop count is 33 on my algorithm, because the first step (a) is to rotate in the previous division result bit and then rotate in the new bit from the division result into the current MOD result. So, obviously if I need 32 bits (even though it's a 32-bit/16-bit division I need to loop 32 times, because of the numerator); then the first step (a) doesn't shift in a result, because a bit result hasn't been calculated yet. Hence I need 33.
However, that means that on the 33rd rotate, the MOD result contains a dummy bit, so it has to be corrected using a LSR #1. And this means that the sign of the result can be stored in that dummy bit at the beginning of the routine. After 33 shifts it's just rotated into bit 0 of the MOD result and after the LSR #1 it's in the carry flag.
So, then I just need to check the carry and negate the result if so! I haven't negated the modulus - I don't yet know if a 68000 has a negative MOD result yet.
But anyway, to me that's a neat trick, because I'd run out of spare regs anyway. I'd have to start pushing a couple of other regs around the routine (e.g. the emulated PC) if I didn't do that.
At the end, I have 25 opcodes; 15 instructions to go!
Those tricks are fun. If you haven’t ever seen the book “Left Brains for the Right Stuff: Computers, Space, and History” by Hugh Blair-Smith, it’s a fun read about the processor designs leading up to the Apollo project.
Hey, it looks like rp2350 has hardware udiv and sdiv- could stuff like that can be supported as an option later down the road?
I've read a few books and articles about processor design, such as Soul Of A New Machine and of course, "Computer Architecture, A Quantitive Approach". I'm a big fan of ARM, because it's a good design that also happens to be British (it's not often we're world leaders in tech). I've done some reading up on the AGC and its weedier predecessor on Gemini (the architectures aren't related though - and as a Brit I pronounce it "Jemmin-eye"). Computer architecture has a fascinating history and often computers are fascinating, because of what could be accomplished with what would be seen as unimaginably underpowered machines now. In turn some computers, such as the pdp-11, were disproportionally influential; though it could also be argued that the original ARM was a sort-of 32-bit Data General Nova given the way shifts and condition code fields were embedded in ALU instructions.
It also has an FPU I think. The udiv and sdiv instructions are candidates for improvements - you'd need two different binaries to support both M0+ and M33. You wouldn't get as much speed-up as you might imagine, because instruction and operand fetch + additional instruction decode starts to dominate the overall time. So, for Divu IF+Decode+EA takes 10+11+26 at a minimum = 47c and execution takes 293c. So, that's 340c vs 140C*125/6.5=2692. So, we're 2692/340=7.9x faster. On Cortex M33 udiv takes 2-11 cycles. Let's assume the average is 8. So, then udiv is 293/8=36x faster than software. But with the other overheads of 47c (giving 47+8=55c), we'd be 49x faster than a real M68000, but that's only 49/7.9=6.2x faster than before.
Again, because MØBius is hopefully significantly faster than a real 68000; then it's worth comparing with a 68030. A 15.5MHz 68030 can do the same DIVU in 44 cycles; giving 44C*125/15.5 = 355c. Wow, MØBius's DIVU should be about as fast as an LC, LC II, Mac II/IIx/IIcx!
Next up: SBCD for me. Now I'm back at another BCD instruction, which held me up for quite a while. I'm starting by copying my NBCD code. NBCD is computed as 0x99-operand -1 - SR.x. I do it that way, because 0x99-bcdVal can never generate a half-carry and I think that simplified my carry routines. It's possible though that programmers have exploited a quirk of NBCD on non-BCD values, which MØBius won't get right, at least not yet.
It's worth doing an update at this point even though I've only implemented another 2 instructions since the last one: SBCD and OR.
Both of these were a bit slower to implement than they might have been, because it's better to exploit the commonality between related instructions.
Multiprecision Format
In SBCD's case, the instruction format is a multiprecision instruction format shared with SUBX, ABCD and ADDX:
SBCD, SUBX, ABCD, ADDXxxxxXnxSize<2>MinOp2<2>Mode<1>Xm<3>
SBCD and ABCD don't technically have the Size field, but their opcode bits are 00 which corresponds to a size of byte, and they're both byte operations. The mode is 0 for Dm, Dn and 1 for -(Am),-(An) . So, by having a common routine which picks up both operands (according to the size); I can save some code in the long-term. This saves quite a bit of space, but it's easy to run out of registers since it needs to handle a source, the destination and the address of the destination.
I have a better algorithm for SBCD than I thought I would. SBCD performs dst-src-X => dst. It's tricky to manage the carry from individual nybbles. My SBCD implementation first adds the 'X' flag to src, then performs a normal subtract. There's a carry whenever the BCD subtract would also have had a carry (because if A<B as BCD values, then A<B when interpreted as binary (because BCD values are a subset of the binary ones)). This requires an upper nybble subtract of 0x60. Also, then priming the upper nybble of src with 0xf leads to a carry in bit 8 if you then add the result back (equivalent to src=(src|0xf0)+interimResult). And this is easily tested followed by a nybble subtract of 0x6.
CMPM looks very much like a multiprecision instruction, but it uses (Am)+, (An)+ as its only addressing mode, so I'll still have to handle that separately.
Alu Common Format
Similarly, a number of ALU operations have a very similar format:
OR, SUB, EOR, CMP, AND, ADDxxxxDndSize<2>Mode<3>Xm<3>
Here, Dn and Mode<3>:Xm<3> are fairly conventional, but since all the instructions need to pick up a Dn and EA they have a common initial execution and it's worth picking up both operands in one go; then swapping source and destination if d=1.
For a few of them, the end parts are all the same with common flag updates and storing the result, so I can just have some common code to handle that. Also, SUB, CMP, ADD probably have common flag handling. This reduces the bitwise operations to just 10 or so bytes per operation. At the moment, the common function takes 38b and OR takes another 28b; which means that OR, EOR and AND will average (66+ 10*2)/3=29b.
SUB, CMP and ADD will be a bit longer.
This brings the emulator to 23 opcodes; 13 instructions to go!
OK, so the next update... thanks to these common routines I've made quite a bit more progress in a short time: SUB, SUBX, SUBA, EOR, CMPM, CMP, CMPA, MULU.
SUB, SUBX, SUBA all have the same upper nybble (0x9) and CMPM, CMP, CMPA, EOR do too (0xB); while the next 3 bits are a register and the next bit often a direction or size bit. The general fields for both would force me to use a single Vector target, but I noticed in both cases that because some of the opcodes have a specific value in bit 8, I can split them into 2 vector targets each and use the information to slightly reduce the decode time.
This means I only have 15 opcodes and 9 instructions to go now!
Snial, does everything run in a single thread, or are there useful speedups to be had with using two cores? Like a “read ahead” of the code to prefetch stuff? Perhaps it’s a question for one level higher, eg pico-mac or equivalent.
Hi @adespoton , @Argyle Gargoyle and all the other MØBius fans!
The moment has arrived:
I've Coded All The 68000 Instruction Set!
A few more details about the recent effort, but first..
The CPU emulation itself is designed to run in a single thread and uses 100% of the Cortex M0+. The second core is for background hardware emulation tasks. Examples:
  1. VIA timer emulation might best run on the second core, because mimicking register values, counter overflows or simulating multiple timers using a single RP2040 timer could require quite a few instructions and that would mean the M0+ wasn't emulating in realtime.
  2. Screen updates: passing all the right info to the DMA for each frame is best done on the second core.
  3. Similarly, audio DMA from the audio buffer.
  4. Keyboard and Mouse emulation ought to run on the second core: I'd have to convert USB mouse coordinates into quadrature encoded interrupts, ideally at the right rate.
Not everything, I think, is likely to run on the second core. The serial interface can probably be pretty much directly mapped to RP2040 serial I/O. I covered it earlier in this reply: https://68kmla.org/bb/index.php?threads/more-pico-mac-stuff.48673/post-565152
As I've also covered before, interrupts from the real world or emulated hardware will translate to interrupts in the main CPU emulator core, i.e. translate to Cortex M0+ interrupts. This means the main CPU instruction loop doesn't have to check for them, instead a real interrupt modifies the address in the register that instructions use to resume the main loop on completion of an instruction. That register (kRegNext) will point to the emulated exception mechanism, which restores the proper value of kRegNext on exit (after pushing the exception stack frame) so that the CPU loop continues to be re-entered for subsequent instructions.
I guess reading ahead using a second might help. However, firstly, there's probably not much point in reading ahead beyond the next conditional branch and dynamic instruction analysis shows that branches typically occur every 4 instructions or so. Also, a multi-core emulator would end up with the same kinds of challenges as a superscalar CPU, where lots of parallel hardware is required to check for race conditions and CPUs, by definition execute sequential instructions. It might be possible to accelerate execution by making one CPU do the main decode (up until the next branch) and feeding a simple set of jump vectors to the second CPU. That would mimic an early pipelined CPU or the 8086's BIU.
Muls to Adda Implementations
Most of this was straight-forward. I signed extended the operands for MULS and then jumped to the MULU implementation. I think that's correct. For example, 0xc093 * 0x8044 = 0x607CA70C unsigned, but if I sign-extend them it's 0x1FA5A70C. That corresponds to -0x3F6D * -0x7FBC = 0x1FA5A70C. Similarly, 0x9876 * 0x1234 = 0xAD743F8 (unsigned), but 0xF8A343F8 if sign-extended. -0x678A * 0x1234 indeed is 0xF8A343F8.
AND was identical to OR, but with AND instead!
ABCD as usual was a bit more tricky. I tried to avoid having to handle individual nybbles and their carries by pre-adding 0x66 to the byte value of one of the operands. This has the effect that if a carry had occurred with the BCD values, it'll now happen with the modified hex values for both digits at the same time. Then the carry out to bit 8 is an easy test for correcting the hi digit: I need to subtract 0x60 if there's no carry. I applied another trick for correcting the lower digit. I shifted the lower digit for both operands (i.e. with the second one + 0x66) all the way to the top nybble. Then when I did the single add, the actual carry from the CPU determines if I should adjust the bottom 4-bits by -0x6. This, I think saves a couple of comparisons - or at least it was fun to try that approach!
The most challenging aspect of the $Cxxx opcodes was that they have some pretty quirky decoding:
I reduced the effort on this using the previous technique: some operations can only have a specific 0 or 1 in bit 8, so I was able to split it into 1100xxx0xxxxxxxx and 1100xxx1xxxxxxxx variants and then apply the dual bits decoding technique.
Even though for some cases it'll take a few branches, this is still going to be much faster than a 40 cycle cache miss if I had used a much bigger vector table.
Rotates And Shifts
These were the last instructions to be implemented, because they represent the final proper opcodes (I did F-line at the same time as A-line earlier). There's a lot of common functionality in the rotate and shift routines so I wrote additional routines to handle them, as per the routines I wrote for the common functionality in the SBCD, SUBX, ABCD and ADDX set and the ALU set of instructions.
Most of that was using the same techniques as before, but I biased the code towards compactness because the minimum instruction time is 6 cycles (115 Cortex M0+) cycles. Decoding isn't too terrible, the same shift bit-patterns are used for memory shift/rotates and register shift rotates, but in a different location. I used the same splitting technique to reduce decoding. In this case, all the memory shift/rotates for both directions get their own vector. I still had to do additional decoding for register shifts, because their rotation amount bits (cyan) are shared with the type of rotate/shift in memory shifts (light blue).
The common routines were for picking up both operands of a shift, the shift amount (immediate or register) and the operand size. So, there were two functions: one for memory shifts/rotates and the other for register shifts/rotates. To mark progress in my emulator I used this very handy chart:
It's very compact and allows you to see all the instruction formats in detail. It's mostly accurate - I checked it against my 68K programming pocket reference as I went along. Still, there's an error in the listing for the shifts. Memory shifts are 16-bit word only; which should be obvious, since there's no size bits in those instructions.
Most shifts and rotates map directly to shifts and rotates in the Cortex M0+ instruction set. I handled sizes by performing uxtb/uxth or sxtb/sxth extensions on the data to turn them into fake 32-bit shifts that generate the right flags. Cortext M0+ doesn't support rotate left, instead I had to compute 64-rotate value to get the equivalent of rotate right (register shift/rotate amounts are mod 64).
The only tricky instructions were ROXL and ROXR, because they insert the X flag into the shift. Cortex M0+ can do ROXL #1,data; that's ADC. But I'd have to do a loop if I use that and there's no equivalent of even ROXR #1 on Cortex M0+.
So, instead I used the kind of bit-shifting you'd do in a high-level language. ROXL #n,val is:
(val<<n) | (val>>(33-n)) | (carry<<(n-1)) for Long,
(val<<n)|(val>>(17-n))|(carry<<(n-1)) for word
(val<<n)|(val>>(9-n))|(carry<<(n-1)) for byte
ROXR #n,val is ROXL #33-n,val. It's still going to be much faster than the real 68000 on a Mac even for a 1-bit shift (and very much faster for a large shift, since e.g. MOVEQ #32,d0: ROXR.L d0,d1 will take 64 68000 cycles just for the shift part, whereas it'll take the same time in the emulator.
Conclusion
I've basically reached the first milestone though there might be a few things to tidy up before I get to the next stage. Writing this part of the emulator was really slow to begin with, because I needed lots of support code before I could even tackle the first instruction (MOVE). I got stuck on NBCD because I didn't want to faff around with individual nybble calculations (my code still might be just as slow :ROFLMAO: but at least I had the opportunity to be creative).
Getting a little encouragement to continue with the work; and finding common instruction fields greatly accelerated this stage of the emulator as I went along. Thanks, in particular, @adespoton and @Argyle Gargoyle !
Now I'll take a bit of a rest and start the next phase - assembling it!
The current estimated length is about 3238 bytes. Yes, less than 4kB for the CPU emulation itself! It'll be a bit bigger in reality, because I use a number of short macros and undoubtably I'll have to add some extra code, but it's a great start!
