Mac Classic mess up - am I screwed?
I have a Mac Classic that I got for cheap. It was not working in any way shape or form. I recapped it and now it boots! It has the ram expansion module, so I thought it would have 4 MB of RAM in it. I verified that was in fact the case, though the OS only showed 2MB. I tried moving the jumper and even verified the 4 MB of RAM by installing the module in my known working Mac Classic where I was able to replicate the issue. Either RAM module shows the 4 MB in my other classic, and the logic board I just recapped only shows 2MB regardless of which chassis or RAM module it is paired with.
I then pulled the bomarc schematics and did some research and that directed me towards UH6. I got my microscope out and found that UH6 is completely missing. Seems like that would be the issue. While I was at Vintage Computer Festival Mid-West last weekend, I met Thomas from Amiga of Rochester. He gifted me a 74LS174 to try out. I installed that today and was greeted with a sad mac memory error. I took the RAM module out and tried again, same error. At this point I thought maybe I missed a solder joint or something. Looking at it again, I realized I had accidentally installed the chip backwards.
I rotated it 180 degrees and re-installed. Now I am back at 2MB of RAM.
So now I am at a crossroads.
I am concerned I fried the chip by installing it backwards and don't know if it is good or bad. My other concern is maybe I did have it installed correctly, and there was another problem that I am assuming was me installing it backwards.
I am seeing continuity between pin 53 on the CPU and pin 11 on the 74LS174 now.
At this point, I am looking for a good next step. I don't see a cutout on this 74LS174, so I am not sure how to locate pin 1. That may be a good place to start. Are there any other things I am missing?
The chip will tell you its orientation. It could be a small.dot on the corner, or even a line denoting the top. Send a pic and we can verify it's identification for you. If you put it in backwards it's quite possible it's dead, Jim (my star Trek ref for today 😁). Putting a chip in backwards happens to everyone (even when you know pin one), so don't fret. Worse case I can send you another.
Well - I put this under the microscope to see.
I think I may gave the wrong chip!
In this case it's the chamfer edge that denotes the pin one side.
It looks like a 174 to me. If you ever have any questions about a chip make sure to pull up the datasheet on it.
I pulled up a datasheet and see that it is backwards compatible, so I was wrong there. I think the alcohol took off the line on the left when I cleaned it, so the line is what is showing pin 1. After reviewing, I did have it installed correctly the first time. I am going to reverse it and see what it does.
Ok, I switched it around.
I am getting a 0000000F/00000003 error. This is saying RAM bank B is bad according to this:
Also, when the ram card is installed, the upper left of the screen has some noise on the top line.
I took out the RAM expansion card and got the error that system 7 needs more ram. That makes sense. I put the RAM card back in with no SIMMs installed, same error.
I installed two different SIMMs, put the jumper back and tried again. This time it got much further, but it froze before fully loading the finder. Upon restart, I am getting 0000000F/00000002 now.
I know the logic board needs a recap as well. Voltages are 11.90 and 4.78, so that could part of it?
The plot thickens - If I unplug my zuluscsi and keyboard, it will get to the flashing question mark. This makes me think it is in fact a power issue as well.
I have swapped the board out to a known good logic board classic. The problem follows the board completely, so I am going to pop that chip off and see where it takes me. I am wondering if this is the reason it was missing ion the first place.
OK, coming full circle, I did re-seat the ROM chip and it is now working again with the zuluscsi and mouse and keyboard. I am still at 2MB of ram though.
I think for my next steps, I will make a digikey order and include some replacement 174 chips.
How do I test a 174? I am getting the same sad mad this morning and am wondering if I am running in circles because I installed it backwards.
you'd need an IC tester. tl866/xgecu stuff can work in a pinch, but i've seen busted ICs test good in them so... maybe not the best
Just to clear up things up a little. You didn't wipe a line off with alcohol. If you look at the side of the chip you'll notice it looks like it has a sort of cutout ( a chamfer edge). That denotes the pin1 side. I marked pin one for you so you can verify from this pic. As for testing the chip... you could test the gates still bias, and test for shorts with a meter The only way to properly test it would be with a a scope, LA, or chip tester (requires pulling). The best option is just to buy another and replace it. they''re cheap as chips (literally), and that way you know it's working.
I removed the UH6 chip that I think I fried and it is no longer doing the sad mac and starting and showing 2MB of RAM again.
I ordered another 5 of them and capacitors for the analog board as well. We will see where that takes us!
New 74LS174 came in aaaaand no dice. Just sad macs.
I ordered a reloaded board since I can't find any traces anywhere. I am going to try the 4MB straight on the board mod as well to see if that works.
I recapped the analog board the sound still isn't working on that either. I put my good board in there and no dice. More waiting for parts I guess!
