iMac G3 tray-loading IO door & interposer – reverse engineered replacements
zenaror
I recently worked on an iMac G3 tray-loading shell that was missing part of its IO assembly, specifically the side door and the internal interposer bracket.
Original replacements seem to be quite hard to find, so I decided to recreate both parts via 3D scanning and manual reverse engineering.
IMG_20260425_173409706.jpgThe focus was on maintaining original geometry, mounting points, and alignment with the IO ports and outer shell.
Details:
  • The interposer bracket was modeled to preserve structural behavior and port alignment
  • The door includes a separate ring element (for color matching or multi-material printing)
  • Fitment was tested against the original mounting system
This started as part of a custom build, but it should also be applicable to restoration scenarios where these parts are missing or damaged.
If anyone is interested, I can share the STL files.
View attachment 98180The focus was on maintaining original geometry, mounting points, and alignment with the IO ports and outer shell.
Details:
Great job! Yes, it would be interesting if you shared it; I have two tray-loading drives and neither of them has a cover.
Thanks, I really appreciate that!
That’s exactly the kind of situation I had in mind - these tray-loading units seem to often show up missing those parts.
I’ve made the files available here:
IO Door (outer cover):
https://cults3d.com/en/3d-model/tool/imac-g3-tray-loading-io-door-cover-side-port-cover-replacement
Interposer (internal bracket):
https://cults3d.com/en/3d-model/too...ser-bracket-internal-port-support-replacement
Bundle (both parts):
https://cults3d.com/en/3d-model/too...interposer-bundle-complete-side-port-assembly
If you end up printing them, I’d be really interested to hear how the fit is on your machines!
Nice work - thanks for sharing.
Is that enough USB ports on your iMac? :p
Hahahaha! Now I definitely have!
But unfortunately, this hasn't been an iMac for a long time. It's a brand new DIY All-in-One Linux PC... in a G3 shell hahahaha!
At some point I came across an empty tray-loading shell that was being used as a pet bed, and decided to turn it into an all-in-one PC using modern hardware (mini PC + new display inside the original housing, etc.).
During that process I noticed the IO side parts were missing, which led me down the path of recreating them. A friend was kind enough to lend me the original pieces from his unit, which I used as reference for 3D scanning and reverse engineering.
So while the parts came out of a modding project, they ended up being directly applicable to restoration as well.
I wrote a bit about the overall build here (this was before I finished modeling these specific parts):
https://zenaror.nekoweb.org/blog/po...-de-volta-um-dos-visuais-mais-lindos-da-apple
It turned into a much deeper project than I initially expected.
So.. yeah... no old hardware was thrown away unnecessarily in this project (at least not in my hands).
