iBook G4 (1.33 GHz, Mid-2005) Power adapter?
Hi all,
Having just recently scored an iBook G4 ("Mid-2005") that kernel panics, I need a bit more info - specifically the power adapter. According to EveryMac Specs, the iBook uses a 45W power adapter. Apple shows this one, but all I have is a YoYo. Would the yoyo work the same as the white one?
Thanks,
Kyle-
Depends on your Yo-Yo, If the plug doesn't fit it won't work. there was 2 yo-yos. Ones with a bigger plug that works on G3 PBs and Clamshell iBooks. Later had a slightly smaller plug that worked on Dual USB and up iBooks and G4 PB's. So, if it fits, it works.
Argh. The power supply I have is the one that fits the Clamshells and PB G3s.
It's not something simple that like a pair of pliers could handle is it? (Thinking about the metal ring on the outside...)
Kyle-
