Hi All,
I have been working on my G4 cube. Mainly it was to fix the the sticky optical drive, but in the end, though I got the transport of the discs in and out working brilliantly, I must have broken something to do with the the head as it can't seem to read discs anymore. Anyway, I have a sata superdrive which I intend to fit, using a little ide<=>sata card and 3d printed mounting adaptor.
I made up a new ribbon cable with a box connector on the drive end as that's what it needs to be for the ide<=>sata card to plug in to, which meant having to take the cube almost completely apart in order to fit the new cable into the ide socket for nstead of tye existing cable. In the process of taking apart or putting the cube back together, the fan mounting bracket must have gotten bent, as the standoff that matches with the hole near the power input socket clashed with the two tiny smd caps (C140 and C141) which go between two of the socket pins and ground, breaking both caps in the process
I suspect these are decoupling caps and aren't essential and I that can get away with not replacing them ?
Or
Does anybody know where I can get Circuit diagrams for the cube ?
Or
Does anybody know the value these caps should be ?
Or
Can I get away with just fitting a couple of ceramic disc, say 1uf, caps ?
Anybody any ideas/authoritative knowledge on this ?
Many thanks in advance to anyone who can help.
Or
Or
Or
