Blueberry 2nd Gen iMac White screen, crinkling noises, no startup chime? What is wrong?
The chip is:
EL2386CS​
The passive component amount is:
capacitors:C15
resistors:R836,206,2,177,176,175,640
inductors:L3,4,5
I believe these are all the components you need. If there are more I will update. Again, if someone has a G3 that they can take the values for these that would be appreciated!
Photo's of the bottom of the board.
I believe that this is the full list of parts. I will not continue on this endeavor yet and if I do it will be in another thread. I didn't realize that so many components are missing for the VGA plug. But if you want to attempt this yourself or can fill in values. It would be greatly appreciated.
Resistors:836, 206, 2, 177, 176, 175, 640, 636, 635, 169, 170, 171, 833, 834, 203, 208, 830, 831, 832, 835, 207, 174
Capacitors:15, 16, 198, 194, 196, 243, 249, 246
Inductors:3, 4, 5, 49, 50, 51
VR1
U5 which is a EL2386CS
Alright. I have stopped on the quest...
Tonight I will hopefully get under the motherboard and onto the bottom of the PAV board to inspect for leakage of any kind.
I didn't mean to go down the hole either! :p It just sorta happened...
I am interested if I can get it working after I get it working. It seems like quite the endeavor. I thought it would just be slapping the plug in. But nope!
I took the iMac apart down to the Blue shell (haven't taken that off yet) And thankfully the Front panel that uses clips didn't break! Someone got paint on it before I got it (how?!?!) But Praise the Lord! It didn't break!
Thanks! I thought that you only had capacitor reference in the iMac section.
Is the 400Mhz Graphite the same as the Blueberry 350Mhz? In capacitors that is.
No they aren't both from Oct 1999. One is from 1999 and the other is 2000 or 2001. I'll have to double check with mine, and just quickly scan it over. You are the only person with a capacitor reference that I know of!
