Apple IIe Enhanced RAM Error Help!
Hi there! I was wondering if anyone could help me with this particularly pesky problem of mine:
So I just recently got an Apple //e off of eBay and was super excited as it came with loads of software and stuff. After cosmetically cleaning it I decided to test and see if the Duodisk it came with worked. I hooked everything up, the computer made a startup beep and the Duodisk did it's clacky thing and the drive indicator light came on. After cleaning the Duodisk I inserted a ProDos floppy into the drive. The computer then displayed the ProDos splash screen and then went to "Relocation/Configuration Error" and the drive turned off.
I ran a self test (solid apple + control + reset) and I was met with a message saying "RAM 00000001"
I repeated this process several times, and the result is always the same. I am assuming this means one of the RAM chips is broken, but I have no idea which one.
If anyone could help me get this computer up and running I'd greatly appreciate it!
Ok, so, yeah, it's a motherboard issue. I'd examine the RAM chips and see if any look suspect... AFAIK, the 4164 chips may still be available new.
-J
I've thoroughly looked at all the RAM chips and even cleaned them a little with some alcohol and scrubbing. It doesn't seem like any of them are suspect cosmetically. And yeah, they are all soldered...
What would really help at this point I guess is to find out which RAM chip (f6-f13 I think) the "RAM 00000001" error is referring to.
If you buy one chip you can "piggy back" it one chip at a time and test and the problem should go away then you can replace.
That sounds like a really cool idea! I have an Applied Engineering RAMWORKS III that came with the computer, it's all socketed so could I pull a chip from there to test with? Also, how exactly do you "piggy back?"
I checked one 128 upgrade and it worked, I'm sure the IIe should also. Or at least cause a different issue on the correct bad chip.
So are you saying I can piggyback one of my 6342s on one of the 4264s?
actually, I've never seen or heard of a 6342 (nor can I find a datasheet for it.) so at the risk of offending, are you sure you read the numbers correctly?
