68030 question
mst3k
Will any 16mhz 32bit 68030 work in a Macintosh SE/30?
Probably a silly question, but I am confused. I'm looking for a replacement and the available exact match (MC68030RL-16B) is less available and more expensive than the other 68030 processors I have found.
I see MC68030RC-16B and MC68030FE-16C and MC68030RC-16C to name a few, but I am not sure of compatibility or differences amongst the varieties.
Thanks
Any speed above 16Mhz that's RC will work (FE is surface mount); a higher speed unit will run well at 16Mhz.
