Hi all,
Recenty i got Apple II Europlus model, with two disk drives.
Machine itself is working ok, there was some bad capacitors inside PSU so i replace them,
Since i do not have any floppy disks for machine i tried to use ADTpro, via audio sockets.
And that part is working, but both floppy drives have issues.
I done some research online, but did not manage to solve problem.
When i start to format disk with ADTPro, drive is doing ok until it almost reaches end of disk.
At the end metal pin on head assembly slips out of grooves on white wheel and wheel just turning.
According what i found my track 0 is ok, at least looking ok, dot on wheel is in line with metal pin.
Rails are clean, head is cleaned, also grooves on wheel i cleaned.
Here two pictures of drive with head position at beginning and end position.
Anyone have idea what can cause this issue?
Thanks in advance.
Thanks in advance.
