68k Macintosh Liberation Army
finkmac
finkmac
why are there four battery holders ???
ClassicGuyPhilly
ClassicGuyPhilly
@finkmac was going to use 4 x AA lithium
Compgeke
Compgeke
The original batteries are 3.6V - would this not be feeding ~6V into each position?
Edit: Looking at the wiring I've been trying to figure it out. Are they just extended off motherboard soldered points instead of some series wiring? Dolphins are quite the choice for this, very security alarm installer.
finkmac
finkmac
why not just use cr2032s
ClassicGuyPhilly
ClassicGuyPhilly
@Compgeke you're absolutely correct I would be coming in 0.6v under (2 x 1.5v). For some reason I thought I read somewhere this configuration would work but was a while ago.
Each pair of AA's is directly wired into the original holder terminals, no series.
ClassicGuyPhilly
ClassicGuyPhilly
@finkmac yeah I might need to go that way
J
joshc
Also if you're going to do this, why not put the battery holders outside the case. AAs can still leak.
luRaichu
luRaichu
you're making my IIcx blush
ClassicGuyPhilly
ClassicGuyPhilly
I definitely don't want the batteries outside my plan was to use an external SD-SCSI and mount the batteries where the HD normally sits. Will probably do same but with coin cells now. Thanks for all the input guys!
ClassicGuyPhilly
ClassicGuyPhilly
@luRaichu I do love the Big Boxes, now need an original Mac II to complete the trio!
