68k Macintosh Liberation Army
LaPorta
LaPorta
ADB on G4?
croissantking
croissantking
Yes, how else am I going to install Win NT 4.0? Haha
Fizzbinn
Fizzbinn
Curious, what's on the other side? is everything there on the logic board for ADB, just missing the connector and back plate hole?
croissantking
croissantking
@Fizzbinn a few surface mount components like so and some inductors on the backside. :)
LaPorta
LaPorta
How did you get that on there?
croissantking
croissantking
  • Like
Reactions: Snial
ClassicGuyPhilly
ClassicGuyPhilly
That's awesome! Nicely done
croissantking
croissantking
I was pleased with the cutout too. Drilled a small hole, hand filed it a bit larger, then dremeled with a round grinding bit. The port came off one of your Reloaded boards @joshc :)
  • Like
Reactions: joshc
zefrenchtoon
zefrenchtoon
I have to do the same with mine ...
Also, I would love to get a serial port too
croissantking
croissantking
@zefrenchtoon yes I believe there were a couple of third party options that fitted in place of the modem, possibly by Griffin? A Stealth port or something? It's probably possible to build one yourself as well if you can find something to reverse-engineer (or if you're just very smart).
LaPorta
LaPorta
Griffin iPort was for the iMac. There was a G4 solution as well.
