My fancy new Mac Plus arrived in the mail recently, along with an HD 20SC with a clean installation of System 6. The only other software I have on it Zterm, and Stuffit 3.something. As I don't have anything at all that can read/write 800k floppies (and nothing handy with a SCSI port) I decided to try using a null modem cable to copy some stuff over, using the OS X version of Zterm as the software on the other end. After some fiddling (the USB serial dongle I was using has some problems with hardware handshaking, which made the transfer very slow because Zmodem had to keep resending blocks and wouldn't work at all at speeds over about 4800 baud) I succeeded in getting some files over, but that's pretty much where the success ends.
Every file I copy over, regardless of type (.sit, self-expanding .bins, whatever) gets created on the Plus side with what appears to be a generic "Document" file type/creator setting, which is pretty much useless. That breaks anything self-expanding, and though I was finally able to figure out how to make Stuffit look at the .sits I hit a brick wall *there* because it seems like every .sit out there in circulation needs a newer version of Expander. And I can't get that over to the Plus because of the file typing problem...
Anyone out there dealt with this before, or is there a link to a good howto? (Pretty much every attempt at googling how to do serial file transfers to an old Mac has hit pages that basically mention "you can do it", skip over the rest, and go on to describe how to write mac-readable 1.44MB floppies on a PC. Gee, thanks.) Would it make any difference if instead of using OS X Zterm I set up BasiliskII with access to a physical serial port and used Zterm inside there to copy the file? IE, in that case will Zterm correctly communicate the file type/creator codes when doing the transfer? Or is there some secret undocumented way to force System 6 to execute a file with the wrong file type?
I'm starting to think I may need to bite the bullet and slap together a PC with a SCSI card in it and copy stuff straight to the HD. (I hope the one card I know I still have still works.) Or maybe I could try using the same ancient version of Stuffit that's on the Plus to re-compress things for the transfer? Hrm.
