tecneeq
Yes, there is some yellowing in the first gen iMac already. I have three. One has a good picture, but yellowed case, another has a good case, but bad picture, so i swapped. Here is what i learned:
The case is made of two layers, the outer see-through layer, which is good plastic, not brittle, but has yellowed a bit. And the inner layer, which is some kind of beige plastic that got brittle and darkened considerably.
Both iMacs where bought at the same time and placed in the same classroom. One near the window, but not direct light, one in a darker corner.
So there you have it. Soon your iMac will look like a decaying tooth.
