X-10 Home Automation - Classic Software?
olePigeon
I'm curious if anyone has the official X-10 software for classic Mac OS for controlling the CP290. I have a CP290 with supposedly the correct serial cable and software for Apple II. I can't get it talk to the CP290. I also tried various 3rd party Macintosh and DOS solutions, none of which could talk to the CP290.
I wanted to try it one more time with the official software before I return it, but I can't find it. It's not on the usual places, not even on Archive.org.
I think there was Mac software, the Mac cable is also memtioned in the attached, but you could make your own thing in HyperCard to talk to it :)
600 baud is a little slow though!
  • CP290.pdf
  • SerialPortToolkit.sit.hqx
olePigeon
@Phipli Really appreciate it. Unfortunately programming is just beyond me. I need a point & click interface. I've seen the Hypercard stack, but was unable to get it to work with my newer Mac. I do have a Mac Plus, but no adapter for its serial port (I only have a 25 pin to 8 pin DIN.)
I toned out the cable with my multimeter, and it looks correct. The RX and TX go where they need to on the cable. So I'm inclined to believe it's either the CP290 itself or the computer. But the fact that I've tried it on 3 different computers is leaning me towards the CP290 being bad.
I did talk to a chap who runs an X-10 troubleshooting website, but he's overseas and won't be back for quite a while. It's likely the CP290 needs a recap (apparently they all do.)
So I'm in a pickle. Do I keep it and hope a recap fixes it? Or return it and buy a different one in hopes that one works?
Using the official software would help me finally eliminate any other issues. However, I've run the official software form my Apple IIgs, and it couldn't talk to the CP290 either. So I have my doubts the official Mac software will work, but I figured I'd give it one last go.
Have you tried it with Hypercard 2.0 or 1.x?
What about these?
Or this?
olePigeon
Already tried all of those. :) So I'm guessing my thing is broken. That's why I'm looking for the official software, as that's the only I haven't tried.
Nah, I don't think so, by the sound of it they're serial rather than ADB... my obsession right now is ADB devices. =D
Let me know when you pick up an interest in serial boxes ;) I accidentally collect serial I/O boxes.
Although most of them would be fairly easy to clone - they just use commands and data sent over serial in a wonderfully simple way.
The "SmartBox" is awesome though. The developer sent me the firmware source (as a github issue) :
olePigeon
Update on this: My CP290 was indeed broken. I managed to find another one at a thrift store, and then another new-old-stock one specifically for the Macintosh on Craigslist, and they both work fine. Came with the original disk, too, which doesn't appear to have been uploaded anywhere. Disk had a bad block, but it was towards the end of the disk without any data, so I was still able to copy it.
I think the original software is good to have. Even though the CP290 Director is way more capable, the original software will run on a 512k or Plus. :)
I also found an old official Apple RS242 to mini-din serial adapter at work of all places, so I was able to test it on my IIfx. Worked great. Now I just need some modules and I'll be able to control all sorts of stuff. :D
