james_w
So I've been restoring a couple of WGS 9150s. One is an original (80mhz) and the other a 9150/120.
The 9150/80 was exhibiting these issues regularly:
I figured this was all probably RAM related. I removed all the SIMMs and the problems were still there. So then I suspected its 8mb of DRAM soldered to the board.
At this point I decided I might as well replace the 18 electrolytic caps on the logicboard and give it a good clean. The insides were rammed with dust and fluff! I think this machine had sat on someone's floor for years just sucking in all the dirt. It was quite a gross job.
Anyway it's all clean and has shiny new caps installed.
Now it doesn't seem to crash any more, but I get no internal video on boot, just a black screen. My monitor (an NEC 1880FX) knows there's something there as it comes off standby when I boot the machine, but it never gets a full signal.
(as a side note - video works fine from a Nubus card)
Anyone got any ideas? I suspect one or more of the DRAM chips has failed... or something else?
I've searched for schematics in vain. Not sure where to go next diagnosing this.
- crashing with type 1, type 2, and type 3 errors after some usage
- internal video sometimes had random pixels of noise (in random colours) here and there
- occasionally the internal video also didn't work, just a black screen on boot
