Crutch
WindowMenu is a terrific control panel + extension (INIT) pair to allow you to pop up a menu allowing you to select any of the current application’s windows to bring to the front by holding down one or more modifier keys and clicking anywhere on the screen. I like it better than the various other Windows menu type things that clutter up the menu bar and make me mouse all the way up there to change windows.
I just did a little tiny assembly hack to create a “nonag” version of the extension which has the nagware popup removed (otherwise after a number of days it appears on every restart), available at this link. No disrespect to the author intended - if I could find you I would gladly send a shareware fee! It’s a nice little utility.
WindowMenu 1.2.1 - Macintosh Garden
macintoshgarden.org
