PlaceboKoyote
Hey,
I have a Dual 1080MHz mdd G4. By upgrading the FSB from 133 to 167MHz to get that speed, i either broke the onboard LAN Adapter or it's not compatible with the higher bus speed.
So i paid 20€ for a sealed, new in box Intel Dual LAN Networking card and it ran pretty fine, great workaround.
However, i want thr dual mdd to run Sorbet Leopard and the older G4s i have to run tiger and OS9.
But i can't Boot Leopard with the Network card, i get a kernel error, because a lot of Networkcard-chips are incompatible with Leopard but not with Tiger.
Which models are definetly working with Leopard amd are PCI cards that fit an MDD Powermac G4?
Thanks in advantage.
Tim
Tim
