Those caps are shot anyway, you can see the leaked electrolyte, the corrosion is why those parts fell off in the first place, look at how black that solder looks. Even if it was well packed, it would still need to be repaired.
Any board you find will need to be re-capped, so if you can't solder yourself, you'll have to have someone else re-cap the board for you. Those old SMT electrolytics just don't last very well, the old ones have all dried out or started leaking. This particular board looks like an easy fix, just clean it up, re-cap and solder that oscillator back on.
