Hi,
I have a Wallstreet 250Mhz with apparently seems to be a corrupted NVRAM problem.
It boots fine on MacOS 8.1, but no way to make it boot on Mac OSX 1.2 Server. I can go up to the System Utility chooser at startup to choose OSX 1.2, but then I get a screen with a broken folder :
If I choose to boot in OpenFirmware from the System Utility, then I get :
fatal error occured. "no open firmware nvram partition found
Message…
Strange things , the Wally just doesn’t want to boot in OF, and doesn’t want to zap the PRAM too. Only time when I can zap PRAM is after resetting PMU, but then it doesn’t fix the problem. Note I’ve replaced the PRAM battery.
Any tips ?
Message…
Any tips ?
