Volume control strip module
benjgvps
I had to format the harddrive on my powerbook 150 and I lost everything but got some of the things I lost (apps, system folder, ect) from my friend, but I lost all the control strips so I had to find others that replace the apple ones that I lost, but the module I miss the most is the volume control. all of the 3rd party volume controls I can find all have dead links or the sites are long gone. Is there anybody using or have heard of a volume control strip that will get the job done.
benjgvps
Well I think my Xp machine screwed up the achive so I sent you a disk image of stuffit expander to binhex the file.
MacMan
I have now stuffed the folder on my Quadra and sent it as a binhex, hopefully that should do the trick.
MacMan
Hmm, that's a bit odd. I'll try and lok out the version running on my 145b as it is possible the one I sent you is not entirely compatible with your 150.
benjgvps
Thank you, how do like your 145b? my friend was going to give me a 145b instead of my 150 but his dad wanted it. you can probably use the disk image of stuffit expander I e-mailed to you if you don't have it on your powerbook.
