*creepy splitting sound of the earth as a battered humanoid form rises from the earth*
There is no C24 on the analog board. There's a R24, but no C24. I think this is in error, when I did the parts inventory after the parts from Mouser showed up after 1 week 5 months, I thought I was missing a capacitor. So I bought a 16v 220uF cap from a local store for C21, turns out that I already had it and it's just labeled wrong. C21 is a 16v 220uF cap so nothing wrong there.
Too Long Too Confusing: C24 doesn't exist, but C21 does.
E: Also I had to crank up my solder station to 800 deg F (about 425 deg C) to adequately heat up the solder pads. IDK. New tip. Use 99% Alcohol to dissolve hot melt glue. Probably will need another new tip after this + PSU because that poor Hakko tip will be taking some abuse. I wonder if my station needs to be temp-tested: I did replace the tip not long ago, but seems cold. (It's a genuine Hakko FX888D)
