Trash80toHP_Mini
NIGHT STALKER
For starters: Macintosh IIsi @25MHz: NuBus Adapter Complications?
Found some old info on speeding up (Oscillator Replacement Method?) the Macintosh IIsi and am curious if anyone has done this and experimented with the Apple NuBus Adapter thereafter? Very interested to hear about any problems that may have arisen from the modification. Apple's adapter might exhibit strange behavior or might work just fine if it was designed to run on the IIsi at either the 20MHz underclock as released or its 25MHz design spec? The Apple adapter has a 40MHz Crystal on board, the same as the 40MHz Can for the System Clock on the Logic Board. If that's swapped out for a 50MHz can to "chip" the IIsi to 25MHz, does the 40MHz can on the NuBus Adapter somehow stay in sync with the faster system clock logic?
Curious about that as we've been playing with the bared to the bones NuBus Adapter for the IIsi from Radius. Having no crystal on board, that adapter simply halves the 20MHz System Clock on the IIsi 030 PDS to generate the required 10MHz NuBus clock. The Radius adapter would have NuBus running at 12.5MHz in a IIsi at 25MHz as it clocks NuBus at 8MHz when used in the SE/30.
IIsi Clocks:
40.0000MHz - divided by two for System Clock?
31.3344MHz - divided by two for 16MHz reference Clock on 030 PDS?
30.2400MHz - Pixel Clock for Vampire Video 640x480@66Hz Output - per Wikipedia Table
57.2823MHz - Damfino? :huh: Pixel Clock for 640x870 Portrait a/o 512x384 RGB output?
Very interested in hearing from anyone with a Hot IIsi and Apple NuBus Adapter. Wondering about wonky video output refresh freqs from a NuBus VidCard on an over/underclocked NuBus expansion bus for one thing? 8-o
Background:
Thanks to @nickpunt finding a Radius IIsi NuBus Adapter on eBay some time back and letting me know it might perhaps be a new path toward NuBus on SE/30, we were able to tempt @joethezombie into buying it! joe quipped that he officially hates us for that, but he's had the schematic for his DOA adapter done for some time now. Recently, from joe's detailed pics of his card, @Bolle identified the solder side of another (unmentioned in the listing) Radius NuBus Adapter installed where it didn't really belong in a Mac IIsi listed on eBay. @maceffects generously acquired and send same to Bolle, where he got the goods on the formulas for all logic on board. As Bolle said in the eBay Finds thread, it "just works in the SE/30," albeit at only 8MHz.
Goal:
Gotta find a way to synchronize a 10MHz NuBus clock with the16MHz System Clock of the SE/30 which is tied to that line and the 16MHz reference line on its 030 PDS. Generating 10MHz from 16MHz for the SE/30 NuBus adapter should also allow a IIsi version of the adapter to run off the 16MHz reference clock in a IIsi running anywhere between its 20MHz Stock and an FDD torquing 28MHz Clocks.
Phase Lock Looping 16MHz down to 62.5% yields 10MHz. but it can't be that simple? In the first rev. discrete component NuBus implementation Macintosh II, it's a bit more complicated than that.
Macintosh II Clocks:
40.0000MHz - divided by four for NuBus?
31.3344MHz - divided by two for 16MHz System Clock as is the case in the single clock SE/30?
How are the two clocks synchronized and what the heck is that beaded-loopy-thingie at L6?
Suggestions? Answers? WAGs?
IIsi Clocks:
Background:
Goal:
