Have you checked the continuity of your solder joins? If might be easier to use conductive ink if you have to go in again
There's only one that needs moving, PLL #1, and yep, she checks out OK with a multimeter on continuity mode, and the resistance across the solder blob is the same as the other pins (near enough to 0-ohms).
Going in isn't too much of a hassle, since it just involves flipping the bottom cover off. I might try some of that conductive ink - perhaps my solder joint is dry.
Did you just blob some solder across the contacts on yours, or did you actually solder 0-ohm resistors in place?
