Hi,
I'm rebuilding an SE/30 and I can't get it to recognize the internal hard drive to install the OS.
I have the following two HDs available. When connected only to the power supply, the Apple one starts spinning, but the Maxton one does not (I imagine it is faulty at this point). I have not found any pins where I can configure the termination of the SCSI chain.
The capacitors appear to be in good condition. I checked the continuity of the tracks running from the SCSI connector to the UI12 chip and from the UI12 chip to the UJ11 chip with a tester, and there are no breaks.
I don't have any other Macs to test the HDs on, and I have the OS 7.1 installation disks. I've ordered an external blueSCSI, which will arrive in a few weeks.
