BarnacleGrim
I have come to really enjoy using classic Mac OS again, with my 7600 getting a key role in my photowork flow. And with on board SCSI and serial it's the perfect compatibility machine between old and new. But I'd really like to soup it up, in addition to making the photo workflow smoother, I could use it to play all the games that won't run well in OS X.
The first thing to do is add more RAM, which I did once I got it, transferring two 64 MB DIMMs from my old and not so upgradeable Performa 6400. Troble is, almost all the other slots in the 7600 have their latches broken off for some reason. I can't fit another pair. Maybe I could find replacement slots somewhere?
Then it's the processor. There's a 500 MHz G3 and a 1 GHz G4 from Sonnet. The latter is sold out, I don't know what the chances are of finding one, but 500 MHz is in any case a good improvement on the 132 MHz 604.
It only has 1.2 GB of hard drive space. Should I look for a larger SCSI drive, or is a PCI ATA interface something worth considering?
I guess I should also upgrade the graphics. Something like an ATi Rage 128 PCI, perhaps?
The on-board 10base-T is a bit slow, I have an Asanté 100base-TX installed, but I get a bomb on startup when I have the extension installed. I'll write down the error message.
If I have a remaining slot I guess I could add USB or FireWire, but I doubt I'd have much use for it.
