Making my own thread here...
*google* May have found a 36MB 150 module (looks different than a duo module, did they make 150 specific modules?) pricy, but less than 1/2 the cost of a CF monster for the 180. that's what's kept my 180 gathering dust on a shelf now HDD. the IDE drive should be cake to find, or get one of those cheap plentiful IDE to CF adaptors
has a SCSI port for my Asante mini EN/SC and a serial port... don't know I need much more than that. is the screen really that bad?
IDE HDD? beginning to think I should get a 150 and not bother with the 180.
those the only limitations? only have 4MB in the 180 and those modules are not all that common either, and currently no HDD either. want one for occasional use of old 68k software I still have... Most of which is from the days I owned a Plus and later a PB 165, 180 and finally a IIci after that I went PPC(turbo 601/66 in the IIci)Unless you can get a 150 that you know definitely has had its RAM upgraded (and therefore has the ultra rare RAM upgrade adapter), I wouldn't bother with a 150 unless you a) don't care about the passive matrix display, and B) never plan to use more than 4MB of RAM.
