The Great Gazelle PCI Hack Thread, Part 2
joevt
If you're using the later and better approach (I can't remember who came up with that, sorry, and I don't have the time to look back through the thread right now - @joevt I think it was you?) then I would also be pretty surprised by a performance difference, but my surprise would be far less well-founded.
My patch was originally posted here (at the bottom):
https://68kmla.org/bb/index.php?threads/the-great-gazelle-pci-hack-thread-part-2.38360/post-467825
It's useful because it is not OrangeMicro or Sonnet specific.
Only thing I can think of is whether the slowdown is to do with enabling USB or FW in the OS itself. In other words, "does having working USB hardware attached cause higher CPU usage somewhere", rather than "does the patch cause a performance issue". I've never done or seen any comparative benchmarks here, so that's a pure wild hypothesis.
Both patches should allow USB to work. The question is, for each patch, was the system setup the same when doing the benchmarks?
Superdos
Given it's worth testing for science reasons, I don't see why I couldn't go and zap the PRAM once more and take another benchmark, just to be sure. I'll get to that a little later on this evening and post my findings.
Superdos
So for this, the system setup is exactly the same between all tests, with the exception of the NVRAM contents.
Where OM-FWP is the Orange Micro patch, and the others should be fairly easy to figure out.
Interestingly enough here on the processor tests, you can see where it's now reading just a bit higher than baseline with the gazelle contents.
FPU seems to take a slight hit for some reason over having nothing in the NVRAM, with nothing going on at that, and I even made sure to start the tests with the keyboard and not the USB connected mouse (MS Wheel Mouse Optical with the appropriate Intellipoint extension loaded).
In all tests it seems there's definitely a performance increase having a freshly zapped PRAM, and even after shutdown/restart.
for the zapped PRAM the mouse does not work, so I had to make use of an ADB-attached pointing device.
Now that these scores are here, hopefully it gives a baseline to work against with this mod in place.
once again there's:
  • standard 6500/275 logic board
  • Sonnet G3/L2 400MHz/1M in the cache slot
  • 2x64MB EDO RAM
  • 80GB Samsung SP0802N for booting 9.1
  • Radeon 9200 (w/injected drivers from 9.2.x for acceleration)
  • Eth CS II card in the Comm slot, DEC chipset
  • Orange Micro OrangeLink FW/USB card, HiNT chipset (image attached)
and that should be it.
joevt
I wonder if there's an error margin? Does running the benchmark 5 times show any kind of variability?
Superdos
Let me go and try that. Is there any test specifically you want me to try multiples of, or do you want me to just run CPU/FPU?
Superdos
Just CPU/FPU
so I did it with the gazelle mod enabled, the CPU scores this time around were a 983 solid after both a cold and warm reboot. FPU scores stayed around 1240 as well, compared to the graphs above.
further testing also noted something else, I tried to do anything else to get the scores to drop intentionally whether it was using the ADB mouse or the USB mouse, and noticed when I moved the USB mouse around, FPU performance went down a lot, by 120-150 points or so. however, the CPU performance stayed the same.
benchmarking this system really is puzzling. I don't know if the nvram code itself is the cause anymore or if something else is afoot. it's obvious the FPU bench would go down because there's polling going to the USB ports during the test, but not the CPU? very weird.
I've run out of time that I can work on this tonight so I'll try some more testing tomorrow afternoon.
Tazintosh
Good evening dear cards masters :)
I've been sent here by Knezzen from MacOS9Lives while chatting on Hotline.
Here's my situation:
  • I've recently bought a Combo PCI card (USB + Firewire) hopping to get it work into my Power Macintosh 5500/275 Black Edition.
    Based on multiple contents I've read here and there by stunning guys like you, I choose one with a NEC + HiNT chipsets.
  • My Mac knowledges are good, but up to a certain level: this topic for instance is more like Klingon to me ;) But I've absolutely no fear if directives are good.
  • To make sure the power wasn't an issue, I've powered the internal HD with an external power source and the PCI card using the internal molex.
  • The card is detected: pci1045,c861, revision 16, maker's code 1045.
  • However, neither USB nor FireWire are working.
  • I've tried all extensions set I could find, I've even tried to reinstall Mac OS 9.1 Fr clean (with the PCI card in slot).
  • I've tried either Fr or En extension
  • Nothing worked…
  • I do own an Adaptec PCI Card, USB only, that perfectly works.
Is my case solvable? :D
Powerbase
Barring any issues with the PCI bridges on PCI cards in those machines, are those chipset supported by any Mac drivers even? I did a quick search and couldn't find anything.
I would try @joevt's patch, it's better than mine in nearly every way - I believe there's a patcher application to apply it upthread somewhere (sorry, I'm not in a position to look for the link at the moment).
joevt
5500 ROM has the same version $077d.35f2 as the 6500/TAM so the patch should work.
A patch app is at #235
The patch is described at #232
A better patch would fix the ATI fcode so that it doesn't matter what order it is loaded.
Tazintosh
Thanks you @cheesestraws and @joevt!!
Can't wait to try it out!
I missed the patch app post somehow, that's a great news for me because the patch description is actually this Klingon part of the topic I was referring to :D
Out of curiosity, can the patch fail? What would happen then? If bad, can we revert?
Tazintosh
"Good News Everyone!"©
You guys are blowing my mind!
  • So I used the app (laugh and sweat a little while reading the in-app process comments 😅)​
  • Rebooted​
  • Plugged a USB Stick, BOOM: working! 🤯
  • Plugged my click wheel FW iPod, BOOM SHAKALAKA: working! 🤯🤯
  • Made multiple read/writte ≈ 700 MB copies in different directions and all together (USB + Firewire): all working.​
You made my Christmas gift in advance. Thank you so much! 🤘
In case you're interested:
  • Apple System Info now detects the PCI Combo card as an Ethernet Card.
  • Firewire drives/volumes are not visible here.
  • USB drives/volumes are visible under USB 1 section (not USB 0). And actually, this section stays visible even if no USB drives are attached. It gets empty only when Firewire drives are also disconnected. So even if the FW volumes are not visible, they "belong" to the USB 1 section anyhow.
  • Sometime the system crash went ejecting a drive.
