Got a lime Clamshell with broken screen some time ago, that one :
https://68kmla.org/forums/index.php?/topic/25205-galgots-new-stuff/page-3&do=findComment&comment=285312
Except the screen, the thing is in good condition , and could even boot and display part of the desktop were the screen was ok.
anyway , got another good screen from Bibilit, an IBM with the good cable. The broken one was a Samsung. So I had to disassemble to change the cable too … Did that, and thought it would be Ok.
It boots, but to a grey screen :-/ there is the chime, and can hear the disk as it starts the OS and all, but only grey screen. Tried all the usuals, zap PRAM, NVRAM, boot in OF, reset-all… no joy.
Ok … I also have a Blueberry Clamshell with a failed backlight screen. Thought at least all is not lost, I’m gonna try the new IBM screen on the Blueberry. Lucky that Blueberry failed screen was an IBM too, so didn’t had to change the cable.
Guess what ? NO BACKLIGHT :-/ Even though that screen is good.
Okay Then… so maybe it’s the inverter… took the inverter from the Lime (At least I know that one works cause it gives me a bright GREY screen…)
Nahh… Still no backlight.
Okayyyyy... let's try another inverter then. Took one for a working Tangerine...
!%$£&##... STILL NO BACKLIGHT !
From my frustration, These two stayed locked in the closet for few month.
But would see these Clamshells each time I opened that closet, so recently got another good screen. A Samsung, knowing the one from the Lime was an Samsung too, and maybe cause of that grey screen was that it didn’t liked IBM…
Nahhhh… same thing…
So , I have two good screens , each of the correct brand that could work on these Clamshells, but it doesn’t . I’m out of ideas and frustrated.
Should I trash these Clamshells ?
Nahhhh… same thing…
