Terminal emulation software
jruschme
I'm thinking about using one of my older PowerBooks as a serial terminal to a Sparc. Can anybody recommend a decent free terminal emulation package for the classic MacOS?
The last time I did this was a few years ago and I was using the terminal application in ClarisWorks along with a VT-100 Communications Toolbox component. I assume. though, that something better must be out there.
Thanks...
John
jruschme
I used to use NCSA Telnet. I'm sure you can find it laying around the Internet somewhere.
Which would be fine for telnet. What I'm looking for is a serial terminal with a halfway decent VT100 emulation.
Unfortunately, it seems like all the good ones (e.g., Zterm) are non-free. The closest I could find to free would be something like iTerm under OS X combined with cu or screen to make the actual connection.
Anonymous Freak
There are better, but they all cost. In fact, I can't find a single free serial terminal package for the classic Mac OS.
There is Zterm, which is shareware.
Then there is Apple's own MacTerminal, Microphone, and the terminal software built in to the "Works" packages, ClarisWorks and Microsoft Works.
Those are the only ones I can think of. All paid software.
P.S., MacTerminal works great for that task.
Gorgonops
Moderator
Staff member
If OS X is an option "minicom" works well enough. It's a console program rather than GUI but it's relatively user-friendly. (Less hackish than using cu or screen, anyway. It's very reminiscent of Procomm or other similar DOS terminal programs.) You can easily install it with FINK or MacPorts.
(Minicom is the lowest-common-denominator serial terminal program usually included in Linux distributions.)
For classic MacOS... not to endorse piracy or anything, but you're probably not hurting anybody by using "abandonware" at this point.
luddite
Host of RetroChallenge
SyncTerm is worth checking out for OS X, but if you're committed to Classic then I guess ZTerm would be the best choice. If you're using it regularly then paying the $20 shareware seems reasonable... or you can just take your time evaluating it ;-)
jruschme
Having never actually used Zterm before... is the demo time-limited or more of an honor system thing?
John
luddite
It's fully functional, I believe...
How old is your PB, anyway? The only versions still available from the developer are PPC, so the 68K version may well be free/abandonware by now.
msieweke
Red Ryder used to be a very popular shareware terminal package. I still have a floppy around here with v5.0. It's primitive (non-scrolling window), but it runs somewhat on my PB520 with System 7.0.2. It locks up the system when you quit.
There's an old kermit for the Mac. I have 0.9(40) on a floppy here.
