System 7.1 File Server Error
Byte Knight
In the quest to make my IIsi as speedy as possible, I've been migrating from System 7.5.5 to 7.1. The only thing I can't get working in 7.1 that works fine with 7.5.5 is copying files to my netatalk file server running on a Raspberry Pi. Copying files from the server works fine, but when I try to copy to it I get the message "There is not enough room on the disk "ApplePi" to copy "file" (an additional 1897.7 MB is needed)" even though the file is only a few K in size and there's over 19GB available. For whatever reason it thinks the file server is full. Anyone know a fix for this?
LaPorta
Possibly due to an older version of AppleShare. Try installing OT and using a newer AppleShare extension.
Byte Knight
