StyleWriter Capacitor List
elemenoh
I have a StyleWriter that would power up for a couple of seconds and then power off. Tearing it apart revealed leaking caps on the logic board. Here's a map and Digikey cart in case it's helpful to others.
https://www.digikey.com/short/z829n5
In my case, the 100µF caps looked worst and I happened to have them on hand. After replacing them, the printer powered up okay.
demik
Well mine didn't have that luck. Got it in a lot and "does not power up".
The StyleWriter was shorting the PSU. Tried with a 19V Dell PSU and same issue. Opened the beast and caps were as bad as @GregorHouse.
But mine corroded the board somewhat, I had a few vias and traces ripped top and bottom.
The board was always shorting the PSU with no obvious shorts in the board. Tried replacing caps, even without removing caps, tested diodes, not any better. I think one of the chips is shorting the PSU, didn't managed to find the right one.
Dediced with some regrets to recycle the printer and found this...
A corroded and seized motor. Part of the frame was rusted too. Looks like the printer got liquid in it by the previous owner. That would "explain" the PSU shorts...
Anyway thanks @elemenoh, you saved me a few hours! And my Mac Plus now have an Apple Logo. It's the same size :)
techknight
Printers are succumbing to this now too, huh? Darn...
Need to pull out and check my Personal LW 300.
rollmastr
I thought I might add some info on the Rev 2.0 StyleWriter as it uses a slightly different PCB...
C10 - 25V 1000µF
C11 - 35V 2200µF
C3 - 25V 3300µF
C2 - 25V 3300µF
C410 - 10V 100µF
C4 - 10V 100µF
C5 - 50V 1µF
C6 - 50V 1µF
C7 - 50V 1µF
C12 - 50V 0.47µF
Keep in mind that you will need low profile caps for C2, C3 and C11. I had to reuse the old ones.
/edit: just to clarify, this is an original StyleWriter with ROM Rev 2.0, not a StyleWriter II.
