PowerPup
I've lately been trying to find things I can do with my Macs. I had been wanting to do email on my Classic II. But alas, I haven't found any email clients that would work with Stunnel. With or without Baton Mail's help.
Anyway, I did have success with Outlook Express 5.0.6 and Green Mail, using Stunnel to provide SSL. (While OE supposedly has SSL built-in, I could only get POP3 to work.) Both clients support Mac OS 8.1 and higher, though all my testing was done on 9.2.2.
I used the configs from here as reference for setting up Stunnel. I've only tried hotmail so far. but gmail and basically any other server should work.
To set up your client, just enter your full email address and password, and use the IP address of the computer running Stunnel for both POP and SMTP fields. (Make sure SMTP authentication is enabled.)
Whats that? "The proof is in the pudding?" Well, I didn't find any in there, but it WAS good pudding!
Email in Outlook Express 5.0.6 Mac Edition:
Email in Green Mail:
(Ignore the port numbers 8002 & 9002, they were early testing, I just used the default 110 and 25)
Stunnel uses the OpenSSL library. So you might want to make sure it's legal to import/download in your country.
