Struggling with Performa 6360--need help
Are you sure.
Everything I can see says 8MB soldered, shipped with a single 8MB SIMM for a default of 16MB.
If you have 16MB, are you sure that there isn't a SIMM, or that virtual memory is on?
I'm not saying the internet isn't wrong, but it is very consistent in insisting that the 6360 has 8MB soldered.
mloret
Yes you are right, 8 soldered. I misspoke when I said 16 on board. I should have said “default.”
No problem, I probably should have been more clear. I was just intrigued if you had a machine that had loads of built in RAM.
