Sonnet's Tempo Bridge . . .
Unknown_K
Interesting, but exactly why would you want to use an older, slow IDE hard drive in a machine that can take a native SATA anyway?
I have an adapter that converts a SATA HD to IDE to run in older machines.
Gorgonops
Moderator
Staff member
I used to know a hardware guru that would use those SATA->IDE bridges for "torture-testing" new SATA-equipped hardware. (Part of his job was working on device drivers and improving the error-resiliency of same.) He'd use them instead of "real" SATA drives because they were so good at producing spurious errors for his drivers to have to handle.
Trash80toHP_Mini
NIGHT STALKER
Fastest way to move data from an old system to your new G5
I might add: easiest way to do incremental HDD->HDD data backup a/o move new data onto an older machine . . .
. . . and it's a cool toy I nabbed at half the going rate that I can use on the AtomicNetTop right away. [:)] ]'>
Speaking of B@$$-ackwards, does anyone know of an adapter to run a PS/2 KBD/Mouse cable off a USB K/M input? Going the other way costs pennies, but I'd like to run older stuff off the KVM setup at my main workstation and I've already got the PS/2->ADB conversion covered.
Gorgonops
Moderator
Staff member
Huh. It does exist, but whoa Nelly, it's not cheap.
Trash80toHP_Mini
NIGHT STALKER
< gasps for air > 8-o I figured it'd cost a bit, but that's just a bit more than a bit. I'll either have to put up with redundant I/O clutter or go back to the PS/2->USB converters on the NetBook & Pismo and that PITA IR wireless Logitech K/M rig. That's fine for the old-school collection at the easy chair, but I don't really wanna go there on the desktop.
Trash80toHP_Mini
NIGHT STALKER
I really <3 Sonnet!
After two years and close to six months months spent procrastinating over the purchase of a real SATA drive for this Intel NetTop board, it's up and running thanks to this elegant little doojihickey from my favorite Accelerator company . . . since the Jobsian hammer dispatched radius to MacValhallah anyway, along with most of the rest of the Clone makers . . .
. . . whatever, the aTOMICnETtOP™ has been remixed and boots to more than just a live session form the 9.10 NetBook CD! [:D] ]'>
NJRoadfan
SATA<>PATA bridges really aren't anything special. The standard was designed for them in mind.
The first SATA drives were just PATA units with adapters integrated into the PCB. Could you believe that was 10 years ago already?
Trash80toHP_Mini
NIGHT STALKER
Yep, got a couple pieces of Chinese Costume Jewelry for peanuts, no instructions . . .
. . . now that I see how one is supposed to work I can retest the Asian trinkets.
I LOVE all that cheap stuff coming out of China on eBay, but it's not always clear how the heck it's supposed to be used, even when there are instructions included.
defor
You can make up something and come back to it late
Staff member
reviving this ancient thread...
Anyone know what plug type the molex connector's other end is?
I recently tracked down one of these adapters and, before I replace it with a floppy plug I figure I should ask if anyone knows what this plug type is.
