Byrd
Hi all,
In storage I've had a Sonnet Crescendo G4 1Ghz (PCI) CPU card, which I assumed worked, but finally got the chance to try it out in a PowerMac 9650.
Boot fresh install of OS 9.1, chimes and gets past Happy mac, to start of OS 9.1 loading screen, cue an error of one of the following:
"divide by zero"
"error type 10"
"bus error"
"illegal instruction"
... holding down shift to bypass extensions does result in it booting to desktop, but it freezes after a few minutes.
I've stripped the system down to a pair of known good interleaved RAM, basic graphics, single SCSI HD boot and get the same errors. The PPC 9650 usually runs a Sonnet G4 450Mhz CPU card which when reinstalled, works and boots the Mac without issue in the same configuration. CUDA and PRAM have also been reset.
I've checked over the card - there are 6 x 47uF 16V electrolytic caps on there in what appears to be good shape, but what more worrying is the long purple heatsink appears to flex the card. I've re-applied thermal paste and re-seated the heatsink to have less flex on the PCB, and this affects it booting. Tighten up some screws and it'll chime and get to the same errors as before.
I have a vague idea that maybe OS 9.2.2 has better G4 drivers, so I'll try the universal MacOS9lives version next. After this, I'm next at the stage of potentially recapping the board, and reflowing the CPU ... or, any other tips?
Thanks
JB
"divide by zero"
"error type 10"
"bus error"
Thanks
JB
