Simple blank screen saver needed
jasa1063
Can someone suggest a simple blank screen saver other than After Dark for System 6.0.8 on a Mac SE? I just want to dim the screen to prevent burn in and I want to use as little memory as possible. I am currently using Moire 4.01, but that does not have a simple blank screen module.
Thanks!
Byrd
Welcome jasa1063,
the easier method is sometimes the best - turn down your brightness dial when not in use! Less strain on the analogue board and CRT in tow.
MrFahrenheit
I used to use AutoIdle and I believe it had a simple “darken screen” option, but that was 30 years ago so I might be remembering wrong.
Juror22
It looks like Pyro! may have a dimmer contained in it. Earlier versions are available and would be something to try.
