Some background..
For the past few weeks I've been tinkering with a Mac Plus I found in a back alley somewhere near my work. I've managed to get System 6.0.8 installed on it, the "necessary" applications (NCSA Telnet, Fetch FTP, various tools for decompressing/converting .hqx/.bin/.sit files, etc.). I've even managed to get it online with an Adaptec EN/SC unit (which I originally had for my PB 165c), and it pokes along quite nicely!
I had an old dual enclosure and popped a 50MB SCSI HD and SCSI ZIP 100 in it, and I now have "oodles" of external storage. [] ]'> I even lucked out and found an external 800K floppy, which was a godsend since the eject didn't work on the internal one.
The problem..
Years ago I purchased SilverLining 5.8.3, which included SilverLining Light 2.1. Now, the system requirements state System 6.0.7 and above, and any Macintosh, and a 1.4MB HD floppy drive. My Mac Plus obviously didn't come with an HD drive, but 6.0.8 should work. And SilverLining itself works flawlessly.
I'm trying to install the control panel. I'm new to the way System 6 works with control panels (are these "CDEV"s?), and I just dropped it in my System Folder. In the Control Panels window it shows up in the list on the left, but when I click it it chugs away for a bit, populates the pane on the right, and then freezes my computer.
Has anybody had any luck with the SilverLining Light control panel? I need it so that I can install ZIP drivers if required (and format ZIP disks!).
Thanks for any input.
-10d
The problem..
-10d
