Happy Independence Day to all in the states!
Quicktake 150, high quality, no flash and about a mile away from the show.
This program has several zoom options + settings in each option. I just took the automatic. In other variants, you can make sharper or play with the settings. You can add a little noise in Photoshop for sharpness. In any case, the result is much better than simple scaling in Photoshop - tested)
Nice! Any chance you'd be willing to share the STLs or models (assuming that's how you've done it)? I'd love to adapt that to EF or MFT; nothing says stupid like slapping a 16mm cine lens on a 640x480 digital camera!Okay, this is amazing. Feel free to experiment with any of my images.
In the meantime, this is what I'm working on. It's modifying a QT150 for Nikon lenses. The crop factor is about 6x compared to what this lens is usually attached to, so there are going to be some _really long_ shots I'm planning for this.
It's actually not much, and the important part (the metal part that holds the nikon lens) can't be 3D printed. You basically have to take apart a Nikon mount.Nice! Any chance you'd be willing to share the STLs or models (assuming that's how you've done it)? I'd love to adapt that to EF or MFT; nothing says stupid like slapping a 16mm cine lens on a 640x480 digital camera!
Nice work, and nice catsFinally got to use my QuickTake 200... without buying a 5V card.
Instead, I got crafty and designed something myself, a hybrid 5V+3.3V 4MB card based on a Toshiba NAND from the SmartMedia era (another P/N listed in the datasheet is actually a 3.3V SMC), as shown off here:
Loading…
68kmla.org
Good news is that it electrically works, bad news is I forgot the non-notched side is used for detecting a card insertion, so card readers and the QT200 couldn't detect the card
As I figured out my QT200 has a few dead pixels, I decided to just disconnect one of the sensor pins (there is a short if no card is inserted, when the connection's broken the camera considers a card to be inserted). Not too dangerous, as the QT200 will shut off if you open the card slot door anyways (if not, pulling it out could cause short circuits). It also kept tripping the write protect sensor, despite no conductive material being where the WP sticker goes on a SmartMedia card, so I just removed that sensor as I don't plan to use that feature. I know, sacrilegious hardware modifications galore
I also found out I needed a SmartMedia card reader with a specific chipset that could run a Windows 98 era utility called SMPREP.EXE, which both formats the card, and writes the Card Information System header, which cameras use to ID a card. Ended up getting an Olympus MA-USB2, which works with it. Also needed to hack it, long term I could just wire the 3.3V/right side up sensor and 5V/wrong side up sensor together, and have my PCB notched for 5V, so the 5V cameras don't need mods to detect the card.
Anyways, I did end up being able to take photos on the QT200 and transferring them over after that kerfuffle, so have some cat pictures:
Yes, by notching it for 5V. That does require a mod on the card reader (if it's a 3.3V model), by isolating one of the pins on the sensor for 5V or wrong side up detection, and jumper wiring it to the same pin on the 3.3V right side up detection sensor.Is the notch / detection fixable in a V2?
