SE30, desk picture, decor etc
oldmacuser
Décor works fine but does anybody know how to convert images to a PICT format other than using the online service? I have a Pixelmator and GIMP but couldn't figure it out.
jmacz
Adobe Photoshop 3.0. Opens JPGs and TIFFs and can save to PICT files. That’s if you want to do it from your 68K Mac.
On modern systems, there was an open source tool I use (command line tool), which worked but haven’t used it in a while so I don’t recall which of them it was that worked well for me. Might have been imagemagick, but will need to check when I get home.
oldmacuser
Thank you. I will try PS3 on the emulator tonight. The emulators run faster than my real 68k macs. Lol. I will report back later of my results. Thanks again!
oldmacuser
Had some free time during lunch so I tried the conversion from jpeg to pict format using PhotoShop 3. It worked just fine! Thank you!
jmacz
Cool, glad it worked!
For completeness, the command line tool I used was imagemagick. You can get it via home brew on modern Macs. It will also convert many image types to PICT.
