SE RAM with battery bomb damage
Chuckdubuque
Newbie question here. Got a pretty badly battery bombed Mac SE and trying to salvage what I can. One of the RAM SIMMs was hit with battery juice to the point that the gold pin is now green (no gold). I assume this chip will probably be toast? Any danger trying to use it in a known good machine to verify its deadness?
More generally, 1MB SIMMs are fairly readily available so it can be easily replaced at pretty low cost.
Byrd
... time to get scraping! Should be OK assuming this was the only area of corrosion.
Byrd
Yes, scrape it off with the end of a flat head screwdriver, don’t go too hard. Same screwdriver end wrapped with a small piece of fine sandpaper might also help. Also check the RAM slot itself for any corrosion. Long term I’d replace the stick.
Cam
That vertical trace on the left looks a little suspect. If you have a multimeter I'd check it for continuity.
Probably clean/tin the two pads on the left as well.
