SE/30 Screen Shaking
George
Hello everyone, nice to meet you. I got a bad Macintosh SE/30.
At first, it had no chime, but OS was run. And The screen has like checkered pattern.
First image is that state.
So, I recaped logic board. SE/30 got chime, but screen didn`t change.
I tried to wash logic board. Then chime add noise, and screen was shaking. :<
2nd movie is that state.
I got SE/30's schematic, and searched a circuit disconnect.
I repair some disconnects, then SE/30's chime was clear!
Next, I removed UA8 - UG8, and resoldering, then I got SE/30's screen without checkered pattern!
But, screen shaking was there.
3rd movie is that state.
A part of floppy was indicated.
4th image is that state.
I have good Macintosh SE. And I connected SE's logic board to SE/30's analog board and PSU, CRT, the screen was not shaking.
Then, I connected SE/30's logic board to SE's analog board and PSU, CRT, the screen was shaking
SE/30's PSU can output over 5v & 12v voltage.
So I think, logic board's issue.
I searched a circuit disconnect about vsync. But I couldn't find.
I'm stuck.
I'm sorry I'm not good at English, so maybe you can't understand to my information.
But please help me.
  • 2_コンデンサ交換後.mov
    1.4 MB
  • 3_パターン、IC交換後.mov
    4.5 MB
George
Hello everyone. I don't give up yet.
And there was a change in the situation.
I clean up ROM SIMM's terminal and slot carefully .
Then, SE/30's screen shake was gone! :)
But, SE/30's screen got stripe line.
image2 is that state.
I cleaned up around video logic,but did not change state.
So, I want to get screen shot, and ask to advice in this forum.
This time, SE/30 got good screen at once.
image0 is that state.
But, that state was only one time. My SE/30's screen is image2's state right now.
Please tell me the solution of this issue.
joshc
On second thought (actually, because someone who knows better than me saw my post and messaged me about it) this is more likely a bad address line to the muxes - the traces around there may be damaged from the capacitors leaking previously. Check all the connections for the muxes to see if there's a bad trace there.
George
Thanks.
Maybe, 2nd advice is right.
Because, I have another VRAM chip, and I changed before. But didn’t change state.
I checked these connections before, but the situation was changed. So, I will try it again.
George
Hello everyone.
My SE/30 is back!
UD8 to A0 pattern was disconnected, so I bypassed to UE10.
Then, SE/30's screen was clear.
Thank you very much!
