JDW
Use the SONY CR-44 PSU as a frame of reference for the voltages and minimum Current output you will need:
+5V: 6.0A
+12V Sweep: 1.25A
+12V Disk: 2.1A
-12V: 0.5A
Sweep and Disk are not isolated, so you could drive both with a single +12V power line rated at 3.35A or higher. And no, a -12V line rated at 0.3A is not acceptable, in my opinion, since the -12V line of the SONY is 0.5A. Even if a power supply has +5V, +12V and -12V outputs, if the current for any of them is lower than described above, it would be unwise to choose such a replacement power supply.
Another benefit to the SONY CR-44 PSU is that it's complete fanless, unlike any replacement PSU you may be considering (including the SEASONIC).
+5V: 6.0A
+12V Sweep: 1.25A
+12V Disk: 2.1A
-12V: 0.5A
