One should not expect wonders from an
old NCR 53C80 SCSI chip.
http://support.apple.com/kb/TA29470?viewlocale=en_US
This is a repeat of the same old thing numerous people have cited time and time again. But such arguments slap logic right in the face.
It's not about slow SCSI chips in the SE/30!! If we can get 1700kb/s READ and 1700kb/s WRITE with a spinning platter drive on an SE/30 that has that slow SCSI chip, can one then argue that "it's the SCSI chip!" when a CF card gets 1700kb/s READ but only 500kb/s WRITE? Poppycock! I say no!
You can tell me that the SCSI chip in the SE/30 limits the maximum READs and WRITEs to 1700kb/s. I will accept that based on the benchmark evidence I've seen. But that does not explain why the "slow SCSI chip" would limit the speed of SSDs to much less than 1700kb/s! Don't compare the SE/30's SCSI chip with any other Mac. We know it's slower than other Macs. But that is irrelevant to this discussion! We are focused on the SE/30's SCSI chip, and we know the upper limits of the throughput it allows. Therefore, the fastest throughput is what we must focus on.
Putting it another way, the benchmark speeds of spinning platter drives in an SE/30 have become our "reference standard" because we are not seeing any "faster" benchmark speeds from SSDs (even if some contend the SSDs "feel" faster). Therefore, it doesn't matter if the SE/30 has a slow SCSI chip. It doesn't matter if the SCSI chip in the SE/30 is slower than other Macs. None of that matters. What matters is this. How fast are the READs and WRITEs of the fastest spinning platter hard drives when used internally to the SE/30? (From what I can see, it's about 1700kb/s max for READ & WRITE.) And then what is the maximum READ and WRITE speed of the best SSD in the SE/30? (From what we have seen with the Intech HD Speed Tools driver, its about 1700kb/s for READ, but only 500kb/s for WRITE, on a particular SSD setup). So if the upper WRITE speed limit is 1700kb/s for this "slow SCSI chip" why then does a flash drive get only 500kb/s WRITE speed? You cannot argue with me that "it is the slow SCSI chip"!
So as you can see, the SCSI chip is not the limiter of READ/WRITE throughput insofar as our reference standard is a spinning platter drive that we know to get a max of 1700kb/s for READ and WRITE, versus slower WRITE speeds on SSDs tested thus far. Hence, the most logical course of action is to focus our time and energy on the real potential sources of the slow-down:
a) The SSD itself
(we've not yet tried an OWC SSD, but the CF cards tested here seem to indicate it's not the SSD itself)
B) The IDE-to-SCSI interface of the SSD
(which is what we've started to ponder recently)
c) The software drivers
(which I've long thought was the root cause of the slowdown, and we can see Intech HD SpeedTools did max out the READ throughput!)
So it's not about a "slow SCSI chip." Nor can it be about the CPU of the SE/30 either, for reasons I stated above. It's all about (a), ( B) and/or ©.
